Problem with Radiator: can you help me ?
  • Problem with Radiator: can you help me ?
    When i push the radio button, Radiator is beginning to launch but the frequency in RR is equal to the value 0,00. The frequency doesn't change when i push scan, surf or change the frequency manually. These buttons have a null effect on Radiator which is in the taskbar. The playlist is empty too.
    I believe that it is a configuration problem. i tried all the local variables in RR configuration. I suppose that the radiator path is well configured because radiator launch when i push radio button in RR.
    In Radiator the option "Minimize in system tray" is enabled and "Scroll text on taskbar icon" is disabled.
    My system is windows xp french version.
    Can you help me, please !!
    which radio card are you using?
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
      I use a Hauppage WinTV GO FM. Radiator works fine with this card.
        well i had same problem with my setup. it was a problem of the earlier versions of Road Runner exe an it should be fixed in the actual release:
        - be sure Radiator works when launched alone;
        - be sure u installed the last binaries;
        - don't create any presets in Radiator, u'll be able to do this inside RR;
        - try disable internationalisation in config;
        if u check these things, Radiator should run perfectly.
        cheers.
          I made all you said and no change, AHRRG !!!!!!!!!!
          I have installed the Road Runner 03-19-05 Binary.
          The skins is BrushedMetal downloaded on Guino web site
          My version Radiator version is 1.8.0.7 (2003-8-25)
          No presets in Radiator, i tried with option "disable internationalisation" enabled and disabled, it is the same thing.
          Have you an other idea ?
            Same Prob.. Same card... working on it... I'll let you know what I can find... Guino???? thoughts????
              Each of you, please make me a screen shot of Radiator working ALONE (outside RR) -- Make sure it INCLUDES THE TASKBAR... Also, on the same screen shot (if possible) open the calculator and type in 1 / 2 = (One divided by two and hit 'equal') with this I intend to obtain an important regional setting of your system. After that I'll be able to diagnose the problem better.. the 3-19 release should have what's needed to work with radiator in any system, but if the two of you are having issues, I have to see about it.. may be you just don't have radiator setup right -- you MUST (I repeat MUST) disable the "scroll title" option from Radiator.
              Ride Runner RR's Myspace
                Here is my screenshot. I confirm that the "scroll title" option is disabled. Thank you Guino for your work !
                  Please try this "update" (just unzip onto your RR's install location):
                  http://rmc.pimpedwheels.com/rr.exe
                  Let me know,
                  Guino.
                    Let me know,
                    Guino.
                    I disabled scrolling as well as removed the welcome message (before the update... sorry, my fault for not paying attention), solved the hunting problem for me. I can't manually tune any stations, and when I hit "scan", radiator seems to start to scan endlessly no matter what I do. In fact, once I have exited RR, I have to end the Radiator task.
                    BTW I tried the update... no change
                    Here is the Screen Shot
                      I have same problem with RR and radiator. under radiator everything is ok but RR doesnt work correctly with scan function and surf. second problem is that frequency can be only for example 92,90 93,10, 93,30 MHz etc. even you set 93,2 RR always will change this to 93,1 so step is 2 not 1. whats going on? how to change this?
                        Let me know,
                        Guino.
                        Also... not sure, but when I exit radio, audio is still there, and when I change to and play mp3, I still hear the radio. While I am an SE, I am still a total n00b to carputer and RR... so, just like everyone else... I still , ask, and play...
                        I am really enjoying this and really looking forward to the new skin "Digital Graphite' Which will be especially great for the Audi people out there.
                        What a kewl toy
                          Have you been able to get your TV tuner to work correctly WinTV2000? Mine just freezes my system. I am pretty sure I have some video conflict.
                            Originally posted by BMVEE
                            Also... not sure, but when I exit radio, audio is still there, and when I change to and play mp3, I still hear the radio. While I am an SE, I am still a total n00b to carputer and RR... so, just like everyone else... I still search , ask, and play...
                            What a kewl toy
                            Do the same Scan/Seek functions work in Radiator ?? You're using the Hauppauge right ?
                            How do you have the audio setup ? I mean, do you use a audio cable plugged onto your line-in ? if so, what you need to do is tell (In RRConfig) to unmute/mute that audio line when using the radio (in the Radio Section). If you do this (and your cards supports Unmute/Mute) it should not play the radio over the music as you say...
                              I had the same problems... (Using a Etech FM Mouse)
                              But for now it seems to work. I've deleted radiator.ini, re-ran radiator config, have set it to:
                              I also deleted radio.ini from the Roadrunner directory. At last, i changed hidetaskbar=false into true in the rr.ini file. (since the taskbar popped up when rr started radiator)
                              Works for me.. should be a better way, but it works here.
                              My Opel Astra 1993 CarPC: http://www.djsmiley.com/projects/carpc/photos/
