winamp plays when in video mode
  • winamp plays when in video mode
    When I go to video mode and select a file, as soon as it starts playing, so does the audio from my audio mode. any ideas?
    http://jupiter.walagata.com/w/djpm05/sig.jpg
    interesting.. which skin are we talking about.. then the other question is: do you use the built in player or MPC ? And most importantly, does it happen everytime ?
    Ride Runner RR's Myspace
      I'm using the modified red alpine skin and MPC, and yes, it does happen everytime.
        have you tried the built in player ? or are you one of the few users that just can't use it ?
        I'll check it out.. there are a bunch of issues I had to fix with MPC after adding support to confine the video in the skins..
          i believe i am one of the people who cannot use the built in player, i just tried it and whenever i went into video mode it started the song over, and it crashed.
            interesting... I intend to dosome tests here tonight so I'll let you know if I find something with MPC ...
              thank you i'm a little confused by it.
                Well, you may want to try the new version in a little bit.. I have changed a few things with the video player (internally) hopefully that should fix it.. I have tested it here in two machines without any issue..
                  i'll make sure to get it. thanks guino
                    new version works perfectly. thank you
                      alright. the video works, but now it seems like roadrunner has highjacked my audio. I am using an M-audio Delta 44 and when I start RoadRunner it says the volume is all the way down, when I turn it up, it works fine. my WMP9 is all the way up, not muted, and won't play audio, and neither will winamp when it's not opened through RoadRunner. I went into the sound properties for the audio interface, and it is all the way up, but it still doesn't work. what can i do :O
                        ummm... I really haven't messed with audio here... My first guess would be to make sure there's nothing muted in the mixer. then my next guess would be to check if you're running the same winamp in and out of RR, and verify they're using the correct output devices... The last thing I'd do is double check you haven't accidently set RR to mute any audio lines in RRConfig.. this is pretty weird... I never head of it working in RR and not in Windows (I have heard the opposite).
                          I changed the "map master volume to control line": to "all lines" from "master volume" and everything works now. it's an audio interface more than just a sound card, so that makes it much different to work with.
                            glad you worked it out..
                              thank you for spending so much time on this project. Do you know anything about programming a directX plugin for a program like sound forge? :P
