SENDKEY and SPACE key
  • SENDKEY and SPACE key
    Not exactly a bug, but I'll post it in this forum.
    When I try to use the SENDKEY to send in a space it does not work, is there a special symbol for space? Something like ^ for SHIFT.
    I need to send a space to MM so I can automatically go to my hometown when searching Postal addresses.
    Cheers
    -Ruairi
    have u tried {SPACE} ...as u would {ESC} ?
    Check out my SQ Competition carputer install
      {SPACE} did not work for me. I tried it already but not joy
        those are the special keys..
        http://www.mp3car.com/vbulletin/show...1&postcount=21
        for sending a space "SENDKEY; " should most likely work... I cannot guarantee that using a single sendkey can send text to multiple windows in the embbeded application..
        if you post the command you're using (or similar), we may be able to help a little more..
        Ride Runner RR's Myspace
          I seem to have messed up MM because now the internal OSK doesn't work at all. I think I'll need to do a fresh install of MM.
          BTW, is it possible to embed MM in two seperate skin files?
          I'd like to use RR OSK in one skin so RR passes keycode to MM and then in the second skin have normal GPS buttons to control MM.
          I've tried to create a second skin that includes MM but MM doesn't get put in the foreground when I move to the new skin. Something like: Destinator_GPS.skin and Destinator_OSK.skin
          Thank you for all the supprt and hard work you are putting into RR.
            Unless this window you wish to embed is NOT MM's main window, that won't work because MM's main window is already INSIDE RR's skin. You can embed any overlaying dialogs by using the LOAD command and specifying the window title to embed. Otherwiser it is possible to TRY and open up a MENU OVER the current gps screen with the same functions you'd wish to perform. You could most definitely poke a whole in this menu (using the CXX definition) to show the original MM screen behind it.. this of course would require the correct window size etc..
