Application Busy...
  • Application Busy...
    I was checking some places of interest in mappoint and all of the sudden the RR window started flashing rapidly (the RR window in the taskbar did too). A little message popped up saying that the action cannot be completed. This happened many times. Anyone experience this phenomena? All I do is hit cancel and it all goes back to normal again.
    Aopen i855GMEm-LFS with Dothan 1.8ghz
    512mb DDR333
    Windows XPpro SP2
    I don't recommend using that show/hide places option inside RR.. you should set what to show/hide PRIOR to using RR, otherwise I can't predict the results when windows start comming out of mappoint onto the screen.. Once those settings are defined outside RR you can use RR's search for nearby locations in the Add location screen.
    Ride Runner RR's Myspace
