SDK - VB6 App
  • SDK - VB6 App
    Hi Guino,
    I've just tried using the RRSDK VB app to try to remotely exit RR from VB. If I open the code and run the example you give VB closes immediately.
    If I comment out:
    Code:
    Private Sub Form_Load()
        'Prepare to receive messages
        COMHook Me.hwnd
    End Sub
    or
    Private Sub Form_QueryUnload(Cancel As Integer, UnloadMode As Integer)
        'Unhook message API
        COMUnhook Me.hwnd
    End Sub
    It will run ok, but obviously nothing will work, any ideas?? Have tried both with and without RR running, I'm running VB6 SP6.
    Originally posted by UK_MP3Car
    Hi Guino,
    If I comment out:
    Code:
        COMHook Me.hwnd
    End Sub
    or
        'Unhook message API
        COMUnhook Me.hwnd
    End Sub
    You can't make window hooks and don't restore them while IN the message.. or it will crash.. there's a timer in RR just to close it when a "QUIT" message comes it.. I don't recommend testing any hooks in VB's IDE, because if you have to stop your application VB will Freeze/Close.
    Ride Runner RR's Myspace
      Ah k, never thought of that, I found out my problem anyway, it was a DoLog command that always made it crash, even when compiled.
