XM Problem. Runtime Error 5. Please help
  • XM Problem. Runtime Error 5. Please help
    So i indtalled RR, and set up XM and anything else corectly, but when i start RR it pops a Runtime error 5 window. and clicking ok closes RR. It has to be XM related, b/c when i disable XM (put 0 as a port) RR is working fine...
    Any solution?
    The cable and the XMD1000 is good, b/c FrodosatalphaX is working fine. Supscription pending... Please help. as i rater use RR than other software...
    THANX!!!
    what's the date on your RR.EXE ?
    EDIT: have you tried to delete or unzip the original xmcache.ini file onto RR's folder ?
    Ride Runner RR's Myspace
      i have the 8-2*-05 version (*something)
      and no, i don't know where to find the xmcache.ini
      please help...
        please help...
        xmcache.ini is in the RR folder. I had a problem related to this file recently with my XMPCR and RR. Basically, I deleted the "old" xmcache.ini file and replaced it with a "new" one from the RR install package. Just a straight file copy operation. Restart RR, and it works from the new file.
        I understood from Guino that RR should create a new xmcache.ini file on its own by getting the channel data straight from the XMPCR. I may have misunderstood, as this was not what happened for me. I had to manually replace the file. After that, it worked fine.
        MBA
        2000 Ford Explorer Eddie Bauer
        CarPC Status: As of 03 Jan., 2006 - installed & running!
        Epia MII-10000
        512 MB RAM
        Lilliput 7" LCD
        Toshiba 40GB HDD
        Panasonic Slim slot-loading DVD
        Holux GPS w/ iGuidance
        XM PCR
        RoadRunner
          there was a bug causing that error on one of the earliest versions (invalid/inexistent xmcache.ini).. if you upgrade to the latest version, you will not have the same problem..
