Temp. reader...bug?
  • Temp. reader...bug?
    Hi Guino,
    In the new release I have seen that the external and inside reading of the temperatures doesn't work.....
    Tested with Hyperterminal all ok, the kit of reading the temp. works, but with RR no.
    With the version of first I didn't have this problem instead
    Mauri
    yeah... I've had different reports about an issue with this.. tried to fix it for some and screwed it up for others... I have to look into it.
    Ride Runner RR's Myspace
      TNX
      Mauri
        I fixed the issue for next release.. just didn't have time to fix the latest changes..
          With the new update, work all ok,Tnx Guino
          Mauri
            At beginning, thanks for those comma/dot fixes you made few weeks ago.
            Just a notice that there seems to be still some little problem with temperatures. I have both (car & out) temperature scale set to Celcius but sometimes they are displayed as Farenheits. Yesterday they even flash between F, C, F, C, F..
            tim
              You should just leave the board set to C, and have the settings you want in RRConfig... now if you click/tap the labels, they switch between C to F... I don't see any possibility to where it would alternate between the two "automatically"...
                I didn't have notice this label clicking feature before, but now when you told about it I think I also know what's my problem.
                Most probably my touchcreen settings are bit too sensitive, so it will do some clickings from vibrations and temp is changing between C<>F...
                Tim
                  if you change your label code from "TEMPX" to something like: "=||TEMPX" it will most likely never switch from the initial setting ...
