Problem with Resume, Long Delay before Sound unles...
  • Problem with Resume, Long Delay before Sound unles...
    Just getting the software side of things all sorted before I go and organise all my hardware. I've got it all working great, but due to long startup times I need to use hibernation. When I resume from hib. the audio will resume, but unless I move the mouse it won't play for like a minute or so. Not sure what I should be doing.
    Ideas?
    This has been reported on some systems.. try adding this line to RR.INI:
    hibernateaware=false
    Ride Runner RR's Myspace
      Thanks, will give it a try. Sorry bout posting, thought it may have been reported but couldn't find it.
      EDIT:
      OK, it worked, but the clock still won't resume as such until I move the mouse. Music is all good. I'm using the Alpine (Amber-S) skin.
        The problem is that (for whatever reason) RR is not receiving the resume message from windows until you move the mouse. I do not know why, and have never seen the problem myself, which prevents me from ever trying to debug the issue. I can ask you to try a hundred different things and still don't know the cause of the problem... my guess is that some driver or application is causing it. I would try disconnecting the mouse, retarting the computer and trying again (without hibernateaware=false) to see the result, if it actually worked, then we'd know it's something with the mouse driver.
