help
  • help
    when i try to run RR i get error MSVBVM60.DLL error.
    to be exact :
    RR.exe - Unable to locate component
    This application has failed to start because MSVBVM60.DLL was not found. Re-installing the application may fix this problem.
    i have tried uninstall, reinstall. uninstall-reboot-install-reboot still getting the same error.
    has anyone seen this or know how to fix it ??
    Check the install FAQ and download the Visual Basic Runtime from the link...
    http://www.mp3car.com/vbulletin/showthread.php?t=45570
    You should also check ALL the other FAQs...
    Ride Runner RR's Myspace
      Got the same error after clean disk, defrag, check disk....
      08 Lincoln Navigator www.mobiteklink.com
        Haven't you guys used interweb before? A simple google search could have helped you.
        Click this link, download the zip, unpack the dll in your windows\system folder.
