Resume issues
  • Resume issues
    I have noticed an issue with resume...
    The screen is moved over approx 400 pixels, and right side shows on left, and the screen flashes on and off approx once a second. If I close and re-open RR it stops.
    Other problem is after a restart my screen res drops out from 800x480 to 640x480, this is driving me mad
    This is the only issue now stopping my carPC being properly functional
    I am using MC2.0 skin and the last november RR update. MPC, and all internal players. XP SP2.
    I think these problems started after I uninstalled a bunch of unused programs. Anyone got any ideas?
    My Nissan 200SX @ Silverstone
    NOW SADLY WRITTEN OFF!
    My Car's spec list + pics
    Stealth CarPC fab'ing...
    You said it yourself, probably something you uninstalled that messed with your files. Your resolution thing is probably a driver issue -- I mean, I doubt it matters wether you run RR or not.
    Ride Runner RR's Myspace
      Agreed.
      But the screen flashing thing is definately caused by RR as it does stop a few seconds after you close RR. And it doesn't occur again til resume from standby...
        Right - this is getting very strange now...
        Done some more testing and although quiting RR solves the problem, it is NOT the cause.
        If I am on the desktop with nothing running and I pull the power lead out of the lilli, when I re-insert it the screen is flashing with the right of the desktop on the left and all shunted over about 400pixels. It does stop its self if I leave it, but if RR is running it carries on forever!
        The skin in use makes no difference, and it doesn't do it when the screen goes off for engine crank, only when power has been off any length of time. At this stage it does seem to be a Lilli problem! Tried it on two differnet power feeds to and it makes no difference
        I am now pretty sure the 800x480-->640x480 issue is caused by a combination of the registry and the video drivers so once my CD-ROM is attached I will redo those...
