reletive paths
  • reletive paths
    OK, im not sure if there is support for this or not, or full support. But it seems to only work sometimes.
    this code below(placed inside ExecTBL.ini) works fine
    Code:
    "MOUSEWHEELINPUT","RUN;LSTOOLS\SCRIPTS\MMB.exe"
    the full path to the file is C:\Program Files\Road Runner\SKINS\LSX\LSTOOLS\SCRIPTS\MMB.exe
    but this code dosent work
    Code:
    "WEATHERSAT","RUN;LSTOOLS\WEATHER.exe||LOAD;WEATHER_IMG.skin"
    i cant think of any reason why the first one works and the second dosent.
    if i put the full path in the second one it works fine, but i really do not want to use absolute paths at all, as all it does is cause huge problems cuz you cant be 100% that someone is going to have the same path.
    01101100 01101001 01110001 01110101 01101001 01100100 01011111 01110011
    01101101 01101111 01101011 01100101
    beer replenishment fund
    http://www.mp3car.com/vbulletin/forumdisplay.php?f=93
    mp3car live search
    i have joost invites, just hit me up for one.
    ok, i think i figured it out, things are relative to the root of RR, and not the Root of the skin folder.
    mp3car live search
      they're probably relative to the place where you're running RR from, which deoends on the way you run RR.. so I would never recommend using any kind of relative paths.
      Ride Runner RR's Myspace
        actually the problem i was having is i have 2 folders called LSTOOLS, one of them in the root of RR and the other was inside my skin folder. The one inside my skin folder is the one that was giveing me problems cuz it should of been in the root of RR.
        Im not running RR any kind of non standard way or launching it other than from a shortcut.
        When i point everything to the LSTOOLS inside the root of RR, everything is fine now.
        in general i think relative paths are almost a must, at least relative to rr.exe (which is the case), i just wish i knew a long time ago
        mp3car live search
