RR is making winamp sick
  • RR is making winamp sick
    This has happened to me enough to call it a bug.
    When I try to load a big folder in the audio browser winamp takes a dump. I'm talking like painting the toliet bowl brown dump. I have to unistall and reinstall. I tried a couple other things but the unistall and reinstall is the only thing that worked. I open winamp on it's own but crashs. I opened up the task manager while ran winamp and it showed up and ran at 60 percent then closed on it's own.
    Edit: Using 2.95
    Edit: Using 2.95
    Interesting.. some people here will load 9000 songs at once (their entire library) and it won't even break a sweat... my guess is that there's gotta be some specific file or plugin causing the issue.. in any case, the next time it happens, I'd like you to try deleting winamp.m3u (in WINAMP's folder), and see if it loads fine.. if it does, then my theory is most likely true..
    Ride Runner RR's Myspace
      yeah, i load my entire lib all the time and never had that happen.
      beer replenishment fund
      mp3car live search
        It hasn't happend to my again but when it did it happened four times in one night. Will do on deleting the winamp.m3u file next time it happens.
          It happened again, the folder that I am trying to load has 12325 songs in it. Deleting the winamp.m3u file did allow winamp to start again.
            I found the file that was the issue, it was a short cut in one of the folders. The short cut was to a directory that was two levels up. Thanks guino
