Mixer+Mapped Vol+bad
  • Mixer+Mapped Vol+bad
    when you map the master vol to control the wav, when ever you change an eq presets the master volume (in windows mixer) will go to zero.
    Ive had this problem for a while, with changing eq the vol goes to zero, i know it was mentioned here somewhere before but couldnt find the post. But just found if i change the map master vol to master instead of wav it fixed the issue.
    not sure if this has been logged as a bug or not, if so, sorry bout that.
    beer replenishment fund
    mp3car live search
    One thing about the EQ presets you need to know is that it always works in the entire mixer, regardless of settings, so basically, you should SAVE the presets with whatever setting you'll use and then they should work with those settings.. if you by any chance save presets with one setting and load them with another, those presets will most likely not work as desired. That's what I'm guessing in your case: you made presets with the mastar mapped to master, then you changed the setting so master=wave and now your presets don't work right..
    What needs to happen is for RR to stop saving/loading the master when it's mapped to something else other than master -- just never implemented it.
    Ride Runner RR's Myspace
      i tried to save new ones with master mapped to wave but it would never work.
      im not even sure what i have it mapped to in my car, but ill find out when i go to test out this skin.
      mp3car live search
