CPU load label issue when...
  • CPU load label issue when...
    CPU load label issue when... the skin also has a cpu load slider... (label is always 100% but slider display a low load) why? the same thing with volume works great!!!
    What can I do?
    Guino, help me please!!!
    Any suggestions?
    This is my skin... the right slider is the cpu occupancy, in the bottom right there is the cpu label... always 100%
      does the CPU slider work ? cause it's the same code. Is this a NT machine or 98 ? If you can, I'd test it on a different machine to see if it works.. It works fine here.
      Ride Runner RR's Myspace
        the cpu slider works great, the cpu label not. tested on 3 different pc, all with Wxp Sp2.
        This is my main.skin:
        MEDIACAR Skin
        MEDIACAR F-CNS(800X600Stretched)Menu Skin
        MENU_OFF.jpg,MENU_OFF.jpg,MENU_ON.jpg,MENU_DOWN.jp g
        /, F, x, y, w, h, Movie name
        F,270,10,268,246,"clock.swf"
        /, A, x, y, w, h, color;RGB
        A,131,-1,538,374,
        /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
        L,13,546,98,14,200,155,147,14,"Kometenmelodie 2:B","=VOL:","CENTER"
        L,684,546,98,14,200,155,147,14,"Kometenmelodie 2:B","=CPU:",
        L,13,565,103,19,210,200,160,20,"Kometenmelodie 2","VOLUME","CENTER"
        L,684,565,103,19,210,200,160,20,"Kometenmelodie 2","CPU","CENTER"
        L,159,477,483,16,210,200,160,16,"Kometenmelodie 2","TAGALBUM","SCROLL-CENTER"
        L,159,442,483,29,200,155,147,30,"Kometenmelodie 2:B","TAGTITLE","SCROLL-CENTER"
        L,159,415,483,21,140,150,170,22,"Kometenmelodie 2","TAGARTIST","SCROLL-CENTER"
        L,323,503,163,15,200,155,147,14,"Kometenmelodie 2:B","KBPS","CENTER"
        L,486,503,54,15,140,150,170,14,"Kometenmelodie 2","=Len:","LEFT"
        L,164,503,53,15,140,150,170,14,"Kometenmelodie 2","=Pos:","LEFT"
        L,540,501,98,17,140,150,170,18,"Kometenmelodie 2","TRACKTIME","RIGHT"
        L,217,501,106,17,140,150,170,18,"Kometenmelodie 2","CURRENTTRACKTIME","LEFT"
        /, Y, Back Slider file path
        Y01,"lslider\slider_*.gif"
        Y02,"rslider\slider_*.gif"
        /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
        S,132,347,536,27,132,347,536,27,H,05,"miata.gif",8 5,"SONGPOS",
        S,139,384,20,140,139,384,20,140,V,01,"lslider\poin ter.gif",013,"MASTER",
        S,642,384,20,140,642,384,20,140,V,02,"rslider\poin ter.gif",013,"CPU",
        /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
        B,2,2,125,88,"EXITMENU",
        B,2,188,125,88,"VOL+",
        B,2,281,125,88,"MUTE",
        B,161,381,65,25,"MUTE",
        B,2,374,125,88,"VOL-",
        B,2,468,125,60,"GAMMAIND",
        B,130,534,85,63,"PREVTRACK",
        B,220,534,85,63,"FRWD",
        B,312,534,85,63,"PLAY",
        B,403,534,85,63,"STOP",
        B,494,534,85,63,"FFWD",
        B,585,534,85,63,"NEXTTRACK",
        B,673,2,125,88,"GPS",
        B,673,95,125,88,"AUDIO",
        B,673,188,125,88,"LOAD;Video_Player.skin",
        B,673,281,125,88,"LOAD;menu2.skin",
        B,673,374,125,88,"MIXER",
        B,673,468,125,60,"VISU",
        /, I, x, y, w, h, Code;INDICATORCODES
        I,233,381,75,25,"ONLINE"
        I,315,381,72,25,"!NIGHTMODE"
        I,390,381,78,25,"REPEAT"
        I,471,381,92,25,"SHUFFLE"
        B,566,381,73,25,"SCANMODE",
        I,566,381,73,25,"SCANMODE:b"
        I01,161,381,65,25,"MUTE:b"
        END
          i have this issue every time i use the slider and the label at the same time.
          cpu label works great only if used on its own.
            ahhh.. ok, I'll check both at the same time now.. but it may be an issue of the code I'm using for CPU load.
              any news?
                cool skin, is this yours? Or is it avail somewhere here and i missed it.
                beer replenishment fund
                mp3car live search
                  thanks , it's mine... i'll post some screenshots in a new thread, bye!!!
                    I've fixed it.
                      Originally posted by guino
                      I've fixed it.
                      Thanks!!!
