Indicator codes in plugins
  • Indicator codes in plugins
    this may or may not be specific to my machine i know ive been having some strange issues but when 2 different plugins are loaded only the one defined 1st in the menu.skin seems to allow indicators to update labels and button codes still execute but indicators behave strangly and update only if you switch between the 2 plugins
    can anyone else confirm this
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    do standard indicator work all right when using 2 plugins ? or does anything mess up ? there should not be any reason for it not to work, unless you're changing the value of the IND parameter inadvertly.. you should only change that variable to modify the behaviour when processing the indicator code provided.
    Ride Runner RR's Myspace
