Slow visualization
  • Slow visualization
    When I select 'Rotation' to let the trackname rotate the visualization is very slow, just a few fps.
    When I select 'Side-to-Side' the visualization is only slowing down when the trackname actually scrolls. So its only slow with long tracknames.
    When I select wrap text and it scrolls it will always be fast.
    Its always fast in fullscreen mode, I dont know what this issue could be. I have a fast system (amd mobile sempron 3000+, 512mb, geforce 6100) so that cant be a problem.
    This probably has to do with which vis and how it's setup in your machine. You should look for hardware acceleration and overlay options when possible.
    Ride Runner RR's Myspace
      Thanks, I will look into it and report if it helped or not.
      I am using MilkDrop btw.
        I couldnt find any settings for hardware accelleration, but I tried the AVS vis. and that worked like a charm.
