Overflow error
  • Overflow error
    Hi Guino,
    sometimes during the use of RR when I change from menu skin to another skin like music or radio or movie RR crash and a popup tel me "Overflow error".
    Any idea about this????
    I use BMW E36 skin and the only change is a analog .swf clock in the menu skin.
    Alex
    Never heard of that issue (or similar) in RR, did you make the SWF file you're using ? (can you post a screenshot) ?
    Ride Runner RR's Myspace
      The .swf clock is a simplified version of Tissy RR clock (only clock without speedo logo ecc.)
      Forgot to tell in previous...I have an Epia SP1300 with 512 MB of ram....
      Alex
        I meant a screenshot of the error..
          Hi,
          Is only a popup with the message "overflow Error" and the OK button....
          Is not possible to screenshot it because it cause the crash of RR (strange thing...only RR because the music or the radio continue in background).
          Alex
            guino i was having the same problem with tissy's clock and the BMV2 skin ... no one over tissy's thread would beleive me!!! the error went away on its own.. (i was doing a lot of changes to the skin..so i don't know what i did and it went away) my advice is keep your .skin file clean.. revise it keep it tidy and try not to have a label showing time or date in the same skin.. i think that was the problem...(i think?) tell us the result plz.. as i am curious my self
              Now you said something that makes sense.. It's probably some function (within Flash) used to parse the time to display the analog clock. It probably doesn't like the HH.MM format as displayed in the shot above. This is not a bug in RR but in the FLASH object. I would suggest you talk to the author of the flash object OR open control panel and change your time format to HH:MM OR simply stop using that flash object.
                sorry for hijacking the thread
                Guino here is the problem i was telling you regarding freedom and greek charac.
                thanks
                  Hi Guino,
                  more information about the error:
                  "Runtime error 6
                  Overflow"
                  thanks
                  Alex
                    see post #7
