RR Not Responding
  • RR Not Responding
    After a couple minutes of use or after hibernation RR seems to stop responding. A friend of mine has the same problem and we both have the M10000 Via mobo.. anyone have any suggestions?>
    When it freezes:
    -Does the mouse stop working ?
    -Can you use CTRL+ALT+DEL To pull the task list ?
    -Do other running applications stop working ? (i.e. winamp) ?
    Please, make a debug log and post it, also, please list the hardware and software you're using with RR (XM, SIRIUS, Radio card, Destinator, Mappoint etc).
    It is unusual for any hibernation issue to happen other than immediately after hibernation -- that's why I need all that.
    Ride Runner RR's Myspace
      I am having the same problem. Most times I am only listening to MP3s. I am running the latest RR BETA with an SP13000 and SteelBlues. This has been getting progressively worse over the last 3 days. When I start the carputer (cold start/reboot/hibernation) I can click on any buttons a total of about 10 times.
      The RR skin then freezes, somewhat...
      1. The music keeps playing.
      2. The time, speeds keep showing correctly.
      3. If iGuidance is running (not every time), iGuidance works fine
      4. CTRL. ALT. DEL- works fine. brings up task manager, no services are peaking.
      5. I tried switching to 2 other skins... same thing
      6. When this happens you no longer see the background colors of the skin when you touch the screen.
      7. The Touch screen works fine with any other app I bring up.
      8. I have done No Windows updates in the last weeks.
      TIA
      Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
      Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
      99% done... [never completely finished... a continuing hobby]
        That's Weird. Please:
        1-Double check you do not have a GPS, XM or SIRIUS port setup with the wrong setting or to a port that does not have the corresponding device attached to it.
        2-TRY Disabling gestures
        3-See if there's any pattern to what you're clicking at that causes it to freeze
        4-If nothing fixes it, make a debug log and post it.
          I switched back to the latest stable rr.exe (for testing) and all is fine now. I will switch back tomorrow and get you a debug output.
          The GPS is correctly configured. I have no other ports installed/setup
          No gestures
          There is no patern. Different buttons, different screens, different skins...
          Could ou give me a quick how to
            add debugmode=true to RR.INI and run it (till it freezes). then post the debug.txt file created in RR's folder.
              Uppdated my RR to "latest" version (exe file reporting product version 1.0.0.0) of 12.04.2007.
              Before uppgrade all worked smooth and perfectly.
              HW. (I cant remember all the details of the HW. But can be found if i hawe to).
              MSI Mainboard (P4 Celleron 2.4ghz, 512mb ram, Onboard GFX)
              G-Mouse BU-353 (USB GPS)
              Lillput 10.4" (Toutch screen)
              Sound blaster (soundcard)
              D-link (USB Bluetooth)
              ZyXEL ZyAIR B-300 (PCI WiFi card)
              Hawe also tested the same RR version on my Compaq Evo N800c portable computer. Exactly the same happens on that computer.
              This is what happens.
              I start computer from anny mode (hibernated, warmstart, Codlstart) and roadrunner starts as normal. I can now use the frontend as nomral for days. As long as i do not start anny GPS apps or software embedded in roadrunner (Hawe not tryed to start un embedded either). If i enable the com port for the GPS in rr config or start the GPS software as mapmonkey, iGuidance or FreeDrive. Then rr continues to run for a coupple of minutes. Then freezes up. Winamp continues playing seamingly untoutched by this freeze of rr. CTRL+ALT+DEL and i see that rr and the GPS software like FreeDrive or other mentioned is reporting as "Not responding". Everything else seams to work perfectly fine. I hide startmenu and icons + + when i start rr. So nothing on my desktop after forcing rr and the gps software to shut down. But if i opens a folder or other SW before i start roadrunner. Those SW or folders can be used while RR is freezed.
              I have generated a log file. But its way large to poste here. Last lines of the log when it freezes how ever is as follows.
              14.05.2007 16:33:32: Enter Exec: False, menu.skin, "SETLABEL;CUSTOMFDETA;0:00;", False
              14.05.2007 16:33:32: Que Exec: True, menu.skin, "SETLABEL;CUSTOMFDETA;0:00;", False
              14.05.2007 16:33:32: Executing: SETLABEL;CUSTOMFDETA;0:00;
              14.05.2007 16:33:32: Leave Exec: False, menu.skin, SETLABEL;CUSTOMFDETA;0:00;, False
              14.05.2007 16:33:32: SDK command: SETLABEL;CUSTOMFDETR;0:00;
              14.05.2007 16:33:32: Enter Exec: False, menu.skin, "SETLABEL;CUSTOMFDETR;0:00;", False
              14.05.2007 16:33:32: Que Exec: True, menu.skin, "SETLABEL;CUSTOMFDETR;0:00;", False
              14.05.2007 16:33:32: Executing: SETLABEL;CUSTOMFDETR;0:00;
              14.05.2007 16:33:32: Leave Exec: False, menu.skin, SETLABEL;CUSTOMFDETR;0:00;, False
              14.05.2007 16:33:32: SDK command: SETLABEL;CUSTOMFDSATS;06;
              14.05.2007 16:33:32: Enter Exec: False, menu.skin, "SETLABEL;CUSTOMFDSATS;06;", False
              14.05.2007 16:33:32: Que Exec: True, menu.skin, "SETLABEL;CUSTOMFDSATS;06;", False
              14.05.2007 16:33:32: Executing: SETLABEL;CUSTOMFDSATS;06;
              14.05.2007 16:33:32: Leave Exec: False, menu.skin, SETLABEL;CUSTOMFDSATS;06;, False
              14.05.2007 16:33:32: SDK command: SETLABEL;CUSTOMFDMANFULL;P0;
              14.05.2007 16:33:32: Enter Exec: False, menu.skin, "SETLABEL;CUSTOMFDMANFULL;P0;", False
              14.05.2007 16:33:32: Que Exec: True, menu.skin, "SETLABEL;CUSTOMFDMANFULL;P0;", False
              14.05.2007 16:33:32: Executing: SETLABEL;CUSTOMFDMANFULL;P0;
              14.05.2007 16:33:32: Leave Exec: False, menu.skin, SETLABEL;CUSTOMFDMANFULL;P0;, False
              14.05.2007 16:33:32: Enter Exec: False, menu.skin, -LOCATE-, False
              14.05.2007 16:33:32: Que Exec: True, menu.skin, -LOCATE-, False
              14.05.2007 16:33:32: Executing: LOCATE
              And here is the beginning of the log.
              14.05.2007 16:31:47: Start -- Version: 12.04.2007
              14.05.2007 16:31:47: Master Vol: Play Control/4
              14.05.2007 16:31:47: Source: Wave=&H1008/1
              14.05.2007 16:31:47: Source: MIDI Synth=&H1004/2
              14.05.2007 16:31:47: Source: S/PDIF-In=&H1001/3
              14.05.2007 16:31:47: Source: CD Digital=&H1001/4
              14.05.2007 16:31:47: Source: Auxiliary=&H100A/5
              14.05.2007 16:31:47: Source: CD Audio=&H1005/6
              14.05.2007 16:31:47: Source: Line-In=&H1002/7
              14.05.2007 16:31:47: Source: TAD-In=&H1006/8
              14.05.2007 16:31:47: Source: Microphone=&H1003/9
              14.05.2007 16:31:47: Source: Wave=&H1008/10
              14.05.2007 16:31:47: GetLineControl Failed: 401
              14.05.2007 16:31:47: Can't Open Source
              14.05.2007 16:31:47: No Mute for Source
              14.05.2007 16:31:47: Winamp window not found.
              14.05.2007 16:31:47: Shell: "C:\Program Files\Winamp\winamp.exe" /CLASS="Winamp v1.x"
              14.05.2007 16:31:49: Sim.WMSGs: 1
              14.05.2007 16:31:49: Enter Exec: False, menu.skin, , False
              14.05.2007 16:31:49: Que Exec: True, menu.skin, "gesturesoff", False
              14.05.2007 16:31:49: Executing: gesturesoff
              14.05.2007 16:31:49: Que Exec: True, menu.skin, "run;$skinpath$UltimateLCD.EXE;", False
              14.05.2007 16:31:49: Executing: run;C:\Program Files\Road Runner\skins\Ultimate\UltimateLCD.EXE;
              14.05.2007 16:31:49: Shell: "C:\Program Files\Road Runner\skins\Ultimate\UltimateLCD.EXE"
              14.05.2007 16:31:50: Sim.WMSGs: 1
              14.05.2007 16:31:50: Que Exec: True, menu.skin, "gesturesoff", False
              14.05.2007 16:31:50: Executing: gesturesoff
              14.05.2007 16:31:50: Que Exec: True, menu.skin, "SELDL", False
              14.05.2007 16:31:50: Executing: SELDL
              14.05.2007 16:31:50: Leave Exec: False, menu.skin, SELDL, False
              14.05.2007 16:31:50: Enter Exec: False, menu.skin, , False
              14.05.2007 16:31:50: Que Exec: True, menu.skin, "ONSONGSTART", False
              14.05.2007 16:31:50: Executing: ONSONGSTART
              14.05.2007 16:31:50: Que Exec: True, menu.skin, ONLINE, False
              14.05.2007 16:31:50: Executing: NLIN
              14.05.2007 16:31:50: Leave Exec: False, menu.skin, NLIN, False
              14.05.2007 16:31:50: Que Exec: True, menu.skin, "ONSKINSTART", False
              14.05.2007 16:31:50: Executing: ONSKINSTART
              14.05.2007 16:31:50: Leave Exec: False, menu.skin, ONSKINSTART, False
              14.05.2007 16:32:02: Enter Exec: False, menu.skin, , False
              14.05.2007 16:32:02: Que Exec: True, menu.skin, "GPS", False
              14.05.2007 16:32:02: Executing: GPS
              14.05.2007 16:32:03: Shell: "C:\Program Files\FreeDrive\FreeDrive.exe"
              I can make the rest of the log available on request. Or send it as an e-mail.
              Hope to get it back to top notch again. As i love using it.
              oh. btw. Tryed new and old skins. Just changed to a new scin that looked top notch but it needed the new version of RR. When it got unstable. i tryed changing back. But no fix by doing that. The same happens no mather what scin or what GPS SW i use. Same thing happens if i enable RR to use the GPS for things like speedometer, Altitude and so on in a skin.
              For short. As long as i dont use the GPS mouse or unplugg it compleetly all is working top notch.
              All help greatly apreciated.
              (And sorry about lousy english. Im an norwegian carputer lover).
                This thread is older, but matches what I am seeing.
                It worked perfectly before I put the 4-11-07 version on...yes I uninstalled it but the problem is still there.
                I have worked around the problem by autostarting IG when RR starts up.
                This does not occur with the standard skin loaded.
                So obviously something was installed when I put the new version on that is incompatible with my skin...and remained installed when I removed it and reinstalled the older version.
                (logs show nothing out of the ordinary)
                Here is the issue. RR starts, and after a minute or so Windows pops up a box that says something like RR has a problem and is shutting down. Winamp keeps playing in the background.
                So what did the newer version of RR install that did not exist in the older versions...dll files etc?
                current projects
                  Same thing that happened to Niob, rr freeze when i use gps.
                  an debug.txt end always with:
                  Code:
                  05/08/2007 17.59.39: Enter Exec: Falso, every skin that use gps input.skin, -LOCATE-, Falso
                  05/08/2007 17.59.39: Que Exec: Vero, every skin that use gps input.skin, -LOCATE-, Falso
                  05/08/2007 17.59.39: Executing: LOCATE
                  i don't know what is "locate" command, maybe a command that works only with "yankee" positions? (i'm italian, niob is norwegian )
                  edit:
                  localdatacaptureinterval in rr.ini set to 0, it doesn't freeze
                    The Locate command was introduced to determine city/zip and state of the current GPS position -- this is done using a lookup on the Zips.dat file -- which only contains USA data. So if you live elsewhere, you should not set it to try and determine your location -- as it simply won't be able to.
                      Help
                      Hello All,
                      It appears that roadrunner is freezing about 5 minutes after i start it. i have tried different skins and still the same response. I can run winamp and iguidance standalone and everything works fine for hours. I have installed the latest realease and got an error message for the 12/30 version that said installed failed but RR ran and it showed that my version was of the current release. i was following this thread and it seems to have dropped off. can someone give me some guidance. any help would be greatly appreciated. please let me know what information you would need to help. THanks
                      xp sp2
                      1gig ram
                      jetway 1.5 gig proc
                      rr 12/30
                      using night apple skin
                      using teknik red
                        I have the same problem as its outside the USA. How can I disable it?
                          delete zips.dat
                            delete zips.dat
                            Worked, thanks
                              I was just having a problem with my install: about 2 to 3 minutes after starting RR it would become non responsive. Task Manager would show 50+ instances of an Exec.exe process (which I believe came from skins/Digital FX 3.0/Scripts/Exec.exe). I had X-Port splitting the GPS COM port for my BU-353. I unplugged the GPS and disabled Xport and didn't have the problem. I plugged the GPS back in and left Xport off and still don't have the problem. Even tho I more or less solved my problem of RR not responding I still have a couple questions.
                              Don't you need the port split for different apps in RR? I still haven't gotten GPS weather working.. I don't know where you set the port for that..?
                              EDIT: Found the real solution.. had to delete ziplocator.dll from the RR dir.
