Problem with radio stations scanning and adding them to the station list
  • Problem with radio stations scanning and adding them to the station list
    Hello! I just download latest version 06.09.2006 of RoadRunner and install it. When I tried to SCAN LOCAL in radio mode RoadRunner start scan ...87,5...87,6...87,7 MHz and scanning is stopped, now I can't scan and add radio stations automatically, I can only manually set frequency and add them to the list. As I can assume, RoadRunner start scan frequency and when first station is found it can not be added to the station list for some reason and scanning is stopped. I use Radiator to run radio. Before this version I used 07.10.2005 version of Road Runner with same plugins for Radiator and radio worked perfectly therefore the problem is not in Radiator.
    Can anyone help me to resolve this problem? I might to install previous version of Road Runner and forget about this problem but I can't do it because there I can't make russian language be visible in playlist (russian is my native language). But in new version I can't to run radio without problems. I tried in new version replace radio plugin (radio.dll) from previous version and nothing happen but when I replace roadrunner.exe, radio going to scan stations without problem and add them to the list but I can't see russian language in playlist.
    Can any help me? As I saw best assistant here is Guino, right? Guino, can you assume where is problem? Thank you in Advance!
    ...and excuse me for my english...
    AutoPC.com.ua - Automotive Computers.
    CarPC - Kiev, Ukraine.
    See our CarPC projects.
    Sorry for two same threads, it was mistake
      There has not been any modification change with Radiator support for probably a year. Same with language support. My best guess is that you've changed some setting in either Radiator or RR.
      Ride Runner RR's Myspace
        I noticed this also, tried to go back some version and it seems that the 06-03-06 version worked, but from 07-08-06 this has not worked...
        I just replaced EXE, everything else was the same. Tried with WinTV as well as HQCT (i have both), same problem...
          I honestly haven't changed anything with radio support, but I can install a wintv card and try it out.
            I don't change anything in radiator, everything is same, scanning stations and adding them is not working. Please let me know where I can dowload 06-03-06 version? Thanks!
              Get older versions here:
              http://myspotontheweb.no-ip.org/inde.../page0008.html
                Thanks for help but this page was Not Found. Do you have other link?
                  Sorry, try now, link was wrong...
                    Guino, this has to do with ONSONGSTART, did a debug on the old version and compared it to the new, and the new had a lot of ONSONGSTART events while searching, the old version had none of this...
                    2006-10-13 06:57:43: Enter Exec: False, radio_player.skin, , False
                    2006-10-13 06:57:43: Que Exec: True, radio_player.skin, "ONSONGSTART", False
                    2006-10-13 06:57:43: Executing: ONSONGSTART
                    2006-10-13 06:57:43: Leave Exec: False, radio_player.skin, ONSONGSTART, False
                    EDIT:
                    From Requests.txt in 7-8-06 version:
                    -Improved ONSONGSTART to be fired also with radio/sat/video changes
                    This definitely has something to do with this problem...
                      I fixed it like this:
                      In frmSkin:
                      'Generates on song start event
                      CMDQue.Add Chr(34) + "ONSONGSTART" + Chr(34)
                      Just changed that line to:
                      If RSearchMode = False Then CMDQue.Add Chr(34) + "ONSONGSTART" + Chr(34)
                      Now it is working...
                        Thanks! you did a great job finding the issue!
                        I was suspecting something was executing. I as I said, there was nothing changed with the radio support -- this was a generic change that affected the radio indirectly. The best thing however may be to change the rseeking statement on top of Exec() to not stop the search if a command starting with "ON" comes in (because those are just events).
                          This works, if you move the statement below the dummy call, like this:
                          'This is a dummy call
                          If CODE = "" Then GoTo DoneExec
                          'If seeking Radio, quit it, but not on ON events
                          If Left(LCase(CODE), 2) <> "on" Then
                          If RSeeking Then
                          RSeeking = False
                          DoEvents
                          End If
                          End If
                          'Make sure Radio Search is OFF if not using anything allowed during searches
                          If RSearchMode And CODE <> Chr(34) + "next" + Chr(34) Then DisableRSearch
                          Also, can you add a RUpdateList to the "searchpresets" section, to clear the list before searching:
                          Case "searchpresets"
                          DoSearchPreset:
                          If RadioMode = 1 Then DLinkReset True
                          ReDim PlayList(0)
                          ReDim PlayListNames(0)
                          RUpdateList
                          RSearchMode = True
                            Maybe I'm asking like stupid, please tell me exactly where I must to enter this text? I can't understand, I do not know programming. Thanks.
                              this had to be changed inside RR's code, I've applied the changes to the new beta:
                              http://www.rrdownloads.net/BETA/RoadRunner.exe
