PicViewer, playlist and (S) directory
  • PicViewer, playlist and (S) directory
    guino, not sure if this has been covered but here it is;
    I setup a picviewer skin and not having problems, there. Now, when I added a (S) Directory entry in this skin, it works but when I use my touchscreen and double tap a highlighted pic list in the folder/list view area, it will goto the Main menu and then it adds the picviewer entries or pic names to my audio play list thus overwriting my previous playlist??
    In the skin commands.txt file it shows
    / (S) Directory, Launch List, Picture List, etc.
    Now in the skin file it show
    / SD, as RRskineditor doesn't have an entry for Picture List. Is this suppose to be SP or how is this suppose to look like in the skin file?? The Doc files don't enlighten me on this??
    you can't have a directory list and a picture list onto the same screen, I mean, they're both the same thing, so the difference is that on picviewer.skin the directory list is meant to be used for pictures.
    Ride Runner RR's Myspace
      Sorry, I didn't make myself clearer. This is my skin file. And if you have a highlighted filename in the SD window and double tap it, it does as I posted above..
      MEDIACAR Skin
      MEDIACAR PicViewer Skin
      /, SD, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
      S09,698,55,101,419,102,179,255,0,0,0,255,255,128,7 0,103,255,255,255,255,0,0,64,TRUE,14,"Arial Narrow:B"
      /, J, x, y, w, h
      J,1,0,695,526
      /, I, x, y, w, h, Code;INDICATORCODES
      I01,700,528,95,75,"MASTERMUTE"
      /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
      B08,699,1,98,51,"PGUP",
      B08,699,478,98,49,"PGDOWN",
      B01,600,528,99,72,"",
      B02,500,528,100,72,"NEXTPIC",
      B03,399,528,101,72,"PREVPIC",
      B04,206,528,94,72,"",
      B05,300,528,98,72,"",
      B06,104,528,102,72,"SEARCHLIST",
      B07,1,528,102,72,"MAIN",
      /DISCARDABLE
      END
        Oh, I understand now, the double click action is still associated to "SELECT" and that is causing the issue. I'll add a prevention for that, thanks.
