Sliders with multiple Extension plugins
  • Sliders with multiple Extension plugins
    Guino,
    When using multiple extensions plugins and using a custom Slider the slider does not work when is sits in the first extension plugin that was loaded.
    Bug is in function UpdateSliders
    Fixed it like this:
    'Check extension plugin for Slider value
    For t = 1 To UBound(Ext)
    If (Ext(t).ReturnSlider(SLDCODE) > 0) Then Value = Ext(t).ReturnSlider(SLDCODE)
    Next t
    Added red part
    So the Value will only be set is there is a value found > 0. Value was getting reset by the second plugin which does not have the same slider.
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
    I'll add the prevention, Thanks man.
    Ride Runner RR's Myspace
      Did you already add it. I downloaded the latest beta and I noticed my sliders stopped working again.
        This is what the new code is right now. Idealistically ReturnSlider should return -1 for sliders not processed in the plugin, but I'm afraid I may have to remove the = 0 from there for the plugins that are old
        Code:
                        'TotalSecs is just a holder so we only ask the plugin once
                        TotalSecs = Ext(t).ReturnSlider(SLDCODE)
                        'If we received an acceptable value, then we use it
                        If TotalSecs >= 0 Then Value = TotalSecs
                    Next t
