How to Embed any GPS program into Road Runner
This is a sticky topic.
  • How to Embed any GPS program into Road Runner
    Last Updated:
    13/11/2008
    These are the embedding commands used in the GPS configuration on RRConfig (Road Runner - Front End) based on the default paths (See bottom of page for example):
    Supported GPS Programs
    PC Navigator 7.1
    Product Home Page:
    http://directions.ltd.uk/laptop-navigation
    http://www.mapfactor.cz/en/products/...usa-and-canada
    Latest software patch/update:
    http://static.mapfactor.com/files/pc...h-7_1_13-1.exe (adds window support)
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-7-europe.html
    Video Of It In Action:
    [media]http://www.youtube.com/watch?v=aDXyNjZA3aU[/media]Embedding Details:
    GPS Path:C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe
    GPS Window Name:Navigator
    Garmin Mobile PC
    Product Home Page:
    https://buy.garmin.com/shop/shop.do?...484&pvID=14861
    http://www.garmin.com/software/GarminMobilePC_50010.exe
    Embedding Details:
    GPS Path:c:\GarminMobilePC\que.exe
    GPS Window Name: Garmin Mobile PC
    Sygic Drive
    Product Home Page:
    http://www.sygic.com
    Download Demo Version
    Licence for software is paid for by buying maps see this link http://www.sygic.com/carpc/index.html and download it here:
    http://rs5.rapidshare.com/files/66009309/DRIVE_XP.ZIP (Version 7.0)
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-drive-pc.html (Main discussion page)
    http://www.sygic.com/manuals/manual_en.html (owners manual)
    [media]http://youtube.com/watch?v=LjrnfVDmO78[/media]Embedding Details:
    GPS Path=C:\DRIVE_XP\drive.exe |-no-safety -r800x530 (adjust resolution accordingly)GPS Window Name= Sygic DRIVE
    iGuidance (Both 3.0 and 4.0 Versions)
    Buy it here:
    http://store.mp3car.com/iGuidance_4_..._p/sof-019.htm (US $109.00)
    http://www.inavcorp.com/upgrade/navigation/upgrade.php
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-v4-0-a-3.html
    [media]http://www.youtube.com/watch?v=YWoxbmm2xuEmedia[/media]Embedding Details:
    GPS Path:C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    GPS Window Name: iGuidance
    Map Monkey
    Download Full Version (Freeware):
    http://cruise247.s0ulassassins.co.uk.../MapMonkey.exe
    Licence for software is paid for by buying maps, but unfortunetley this software is based on the Desitnator D3 Engine, which is now discountinued, you will need to purchase older maps for this to work (I have read some reports that certain newer maps have worked, but be warned!)
    Links To Research:
    http://www.mp3car.com/vbulletin/map-monkey (Main MM forum)
    http://www.mp3car.com/vbulletin/mm-faqs (MM Faq)
    http://www.mp3car.com/vbulletin/mm-skins (MM Skins)
    [media]http://www.youtube.com/watch?v=rbSGlYH-OPg[/media]Embedding Details:
    GPS Path=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    GPS Window Name = I believe is natively in RoadRunner so not needed
    Free Drive
    http://www.freedrive.co.uk/forums/lo...ks.php?catid=1 (You will have to register on the freedrive forums 1st before you can download)
    http://www.mp3car.com/vbulletin/free...st1149594.html (This is enforcers personal version, seen as freedrive is now abandoned, this version is the most complete, make sure you download the original version 1st)
    Links To Research:
    http://www.mp3car.com/vbulletin/freedrive (Main mp3 FD forum)
    http://www.freedrive.co.uk/forums/lo...ks.php?catid=4 (Skins)
    [media]http://www.youtube.com/watch?v=PeE_lw7ssW0[/media]Embedding Details:
    GPS Path=C:\Program Files\FreeDrive\FreeDrive.exe
    GPS Window Name=FreeDrive
    MapPoint
    NOTE: Mappoint support is available built-in RR. There's no need to embed it as long as you use a skin which supports mappoint for GPS. Otherwise, this information below can be used for launching it as a standard application (NOT recommended).
    Product Home Page:
    http://www.microsoft.com/mappoint/pr...6/default.mspx
    Embedding Details:
    GPS Path:C:\Program Files\Microsoft Mappoint\Mappoint.exe
    GPS Window Name: Mappoint
    Map Point 2009 Europe Edition
    GPs Path: C:\Program Files\Microsoft MapPoint Europe 2009\MapPoint.exe
    GPS Window Name: Map - Microsoft MapPoint Europe
    Streets & Trips
    Product Home Page:
    http://www.microsoft.com/streets/Pro...s.aspx?pid=004
    Embedding Details:
    GPS Path:C:\Program Files\Microsoft Streets and Trips\Streets.exe
    GPS Window Name: Map - Microsoft Streets & Trips
    NOTE: Some version use the window title of: (The AND spelled out) Map - Microsoft Streets and Trips
    Unofficial GPS Programs
    I Go 8
    Read/Get iGo MySize HERE, then use:
    GPS Path=C:\GPS\iGO 8\iGO-MySize.exe|-width=800 -height=412
    GPS Window Name=iGO8
    (Adjust the width/height according to your skin)
    Tom Tom 5/6
    This can only be used using a Windows CE emulator which can be quite complex and/or slow.
    Use Blue ZX3 RRConfig (As including in the latest RR releases)
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    F.a.q.
    F.A.Q. on the above FAQ.
    Q. When I click the NAV button <your Navigation program> does open but it's not embedded. It just opens as a program in front of RR.
    A.
    If it opens but does not embed, it will be down to one of two things.
    1. The window name is incorrect. (use winspector to find correct window name)
    2. The program does not like resizing and won't embed.
    Q. I've finally got it embedded and working, however now it's not receiving any satellite signal. (I think this is because RR is intercepting it from the com port)
    A
    . Either use a com port splitter or don't enter a value for GPS port in RRConfig.
    My Fiero Build Thread
      Great idea. It should be expanded to all apps (not just GPS) like for instance the "sexy attached Analyzer" that's difficult to embed without just the right window name (which i don't remember right now).
      OLD SYSTEM (DEAD)
      Intel D945GCLF2 Dual Core ATOM
      Lilliput 7" 629GL 2008 LED Backlight
      BU-353 USB GPS Receiver / iGuidance / IGO8
      M2-ATX Power Supply
      RideRunner Front End / Various Skins
      Windows XP SP3
        Good reference material!
        Cheers
        Leonardo Da Vinci
          im gald to see the intention was to add more than the original 3 that were posted can wait to see a completed list
          MY build...a walk thru, finally getting to it
            List updated
            Ok, il add sub categories, just post whatever the details are in the same format, and ill add it
            Keep em coming, anyone that can fill in the blanks
            CarPuter Progress:
              Map Monkey
              Free Drive
                Thank for the info!!
                While waiting on my HD Radio cable I'm moving to my next add-on and this is a big help thanks.
                For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
                  Ok Thread is now a sticky. Please keep all posts on topic and no unnecessary posts
                    hha meddler beat me to the punch I was watching the thread to see more items added before making it a sticky. I edited the title of the thread, as it is now a sticky, and did not need the )May want to make a sticky) in the title.
                    I also edited the post to include a link to iGuidance, as well as the price.
                      Originally posted by Enforcer View Post
                      May I suggest the links are checked for any referer ID's and try and have links to a number of sources if possible, rather than just one.
                      any links il updated them, ive just googled most of them...
                      Anyone else got anything to add to the building lists (videos, links etc)
                      CarPuter Progress:
                        I think one link is good enough to go to a page that has detailed information for the software. Preferably the manufacturers site. Then you can compare features and such. If you then decide on one, you can easily google different stores that carry the software and shop around.
                        The other option is to have multiple links for each one, and then try to decide what links to include or not include...
                        For instance, if you like I can give you probably 100 links where you can buy Map Point, Streets & Trips or iGuidance easily
                        I think a chart to compare GPS programs easily would be extremely handy. Such as listing features that each has, such as Text to speech, 3D View, Voice Activated ect ect... (GPS Programs across the top, and features down the left, and X's in the columns for features for each one.
                        Just not sure how to do that in the forums, as some sort of table would be needed.
                        Here are a couple that were overlooked, and probably for good reason, as they are not really touch screen friendly, though Map Point is supported at the heart of RR, and has many skins to make it much more usable in the car.
                        MapPoint
                        Product Home Page: http://www.microsoft.com/mappoint/pr...6/default.mspx
                        Embedding Details:
                        ;Map - Microsoft Streets & Trips"
                        Streets & Trips
                        Product Home Page: http://www.microsoft.com/streets/Pro...s.aspx?pid=004
                        Embedding Details:
                          I think it's.....!attachanalyser!Classic Specturm Analyzer
                          at least that's what i use and i have never had an issue.
                          Motherboard: Epox MATX
                          Power: M2-ATX
                          Storage: 120gb 3.5"
                          Optical: Slim Slot cdrw/dvd
                          Audio: SB Audigy 2
                          GPS: BU-353 & iGuidance 4
                          OS: Win FLP (Fundamentals)
                          Frontend: Roadrunner (DFX 3 & 4)
                            OK John, the list is now revised
                            CarPuter Progress:
