Guide to using RR v4-1-09 NEW HORM features for EWF Systems
This is a sticky topic.
  • Guide to using RR v4-1-09 NEW HORM features for EWF Systems
    Requirements:
    - EWF setup and enabled
    - RR v4-1-09 and Winamp must be installed on the EWF protected drive (installing on a unprotected drive will cause corruption errors)
    - USB flash drive (USB external harddrives won't work)
    1: Check to make sure you have the following settings in rr.ini:
    hibernateaware=true
    hormdrive=x (where x is the drive letter of your connected usb flash/thumb drive without the ":\"; i.e. e, f, g, etc.)
    2: Connect usb drive
    3: Start RR
    4: Clear Winamp Playlist
    5: Make sure you have all your required programs running or not running (i.e xport, gpsexec.exe, iGuidance, etc.)
    6: Hibernate thru RR
    You have now set your HORM point.
    After you resume and add your playlist, listen to radio, whatever, it is IMPORTANT to shutdown the system. Shutting down SAVES your resume information to the USB drive to be used on your next powerup/resume.
    If you've setup your EWF system correctly, even after shutting down your sytems will result in your system resuming everytime.
    If you find that you are not resuming the last playback position, adjust the following rr.ini setting:
    resumedelay=x (where x is in seconds)
    (this allows TIME for the USB drive to reconnect to the system)
    and repeat the steps above.
    Simple.
    Big thanks mitch for his hard work on getting this feature working correctly.
    ALSO, look at DEBUG.txt, there is alot of HORM info there
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    TY for the Mini-Guide!
    Oh, if you use RRCONFIG to set your HORM save Drive, make sure you have it plugged in before u start RRCONFIG
    it will see that a USB Removable drive is present, and offer that choice for HORMDRIVE
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Good to know.
        Is EWF-HORM only available on XPe? Or can it also be enabled on XP Home?
        Thanks....
        Mark
        Project completed! (almost)
        My Truck as featured in Custom Classic Trucks magazine.
          Thanks....
          Mark
          Theres a tutorial under Optimization forum that can take some of the features of XPe and apply them to XP Home. Namely, EWF.
            Shouldn't a guide for setting something up explain what it is?
            Ampie Case
            256 MB DDR2 PC5400
            Xenarc 700TSV - VGA Monitor
            Intel D945GCLF Motherboard
            M2-ATX-HV
            2005 Honda Civic
              Already of plenty of info in the archives that explains the nitty gritty of HORM & EWF.
              Besides, to utilize the info posted above, the user should already know about the topic at hand before attempting to use the new HORM features of RR.
                And if one has to ask what is HORM OR EWF then they need to research lots before even asking any Q's.
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  So the only thing the usb drive is used for is to store the resume data, correct?
                    yes... im sure it can be used for other stuff too
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Well, I am going to run my OS on an 8GB CF card, so I won't need anything big. I have a 256mb usb stick just laying around I can use.
                        Can the "USB Drive" be an un-protected partition on the protected drive? Or do I have to use a USB?
                        -CoryF
                        2001 Camaro SS #2070
                          NOPE, HAS TO BE A USB DRIVE!
                          unprotected drives, while unprotected, are still cached in the hibernation file
                          the whole EWF is a hack by microsoft...
                          im sure it will be better on next embedded os
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Well, my interpretation of embedded is not quite the same as running xp with ewf/horm. In an embedded system you usually have the "image" written in a ROM type memory and any thing that would change would be written to ram. So its like comparing apples to oranges...
                            Makes sence in my head, but probably not here..hehe
                            DFX 5.1.1 Skin
                            Appstore Link
                            RRMedia
                            RRExtended
                            DFXVoice
                              Originally posted by Sal R. View Post
                              Requirements:
                              - USB flash drive (USB external harddrives won't work).....
                              Which USB flash drive is most recommended by those who have done this?
                              "Imagination is more important than knowledge." -AE
