Next & Current Street Labels from iGuidance
  • Next & Current Street Labels from iGuidance
    Thread title says it all.
    Will allow you to use the two street names from iGuidance in any RR screen as labels. The current street is optional, which you can choose when you run the setup.
    It works with all versions: v2, v3 Reg, v3 UMPC
    User specified label variables (defaults are given)
    5-26-07
    The setup has the following changes:
    1. Minor bug fixed
    The OCR app has the following changes:
    1. Option to only read/update upon exiting of the guidance screen (on by default)
    2. Few minor bugs fixed
    To turn off the reading only after the guidance screen closes, under ‘Run’ section in the INI add ‘guidance=false’
    Setup OCR.zip
    5-10-07
    1. No more default letter defs or scanning for it
    2. Turn arrow color message
    3. If learning file is found, jumps straight to teaching then exits
    3. New Icon
    4. Reduced Memory usage
    5. Kill OCR.exe if running when started
    1. Improved check if enroute
    2. Empty columns for letter space detection exposed in ini
    3. Learning on-the-fly ability added ( saves unknown scanned data to file for latter teaching via setup)
    4. Asks if you want to teach the unknown letters if above file found.
    5. New Icon
    6. Reduced Memory usage
    7. Current street does get updated (if turned on)with or without a next street change.
    If you notice that you have some extra spaces where there are not supposed to be, like in the middle of a street name/number, then increase the 'empty_cols' setting under the advanced settings section by one.
    (this just tells the app how many empty columns count as a space)
    Also included is a OCR Toggle.exe - add to a button w/ a run command if you would like to have a way to start/end the app..
    known issues still:
    NONE!!
    Setup OCR.zip
    4-22-07
    Added next turn direction label ( left, merge left, right, merge right, u-turn)
    Added next turn direction text to use for each direction (user specified, defaults given)
    Removed speaking section
    Because of major changes, please delete everything in the folder where you were using the last version, EXECPT the data folder, unless you want to re-learn your letters.
    Skin labels will have to be changed, as new version uses variables so that they will be self updating when changing screens, easier to just let RR handle this instead of polling RR and checking if you changed screen and update labels on each screen.
    The current label variables are (user can specify when going through setup):
    Next Street: “=$_NEXTSTREET_$”
    Turn Direction: “=$_TURNDIR_$”
    Current Street: “=$_CURRENTSTREET_$”
    example skin label line
    Code:
    L02,244,59,152,17,255,255,0,12,"Arial:B","=$_NEXTSTREET_$","CENTER"
    4-13-07
    Added next street speaking, runs when next turn label gets updated
    To use add these 4 lines to the OCR.ini file
    Code:
    [Speaking]
    speak=
    command=
    pre street=
    speak - True/False
    command - Say/Talk
    pre steet - text to be say before street name..ie next turn, next street, ect
    speaking beta
    Edit: file removed, needs more work yet.
    Seperate OCR.exe file, only use if already went through the setup.exe
    Edit: file removed, will not work with new version
    4-8-07
    Updates labels upon changing screens.
    4-1-07
    Here is the next version, now fully operational!! Just place the setup in the same folder and run through again. your shouldn't have to relearn your letters if you didn't delete the files, but I've added some of the letter combinations to the letters left to learn box.
    Its at the end of its beta testing in its current state.
    Doesn't do yet (DONE):
    Send street names to RR
    Doesn't check for iG window visability
    Doesn't check if you actually have a destination set
    Only real requirement is that your RR is no older than than the Oct release.
    Setup is best run when its in its own folder, its not that picky just easier to keep all files in one location.
    Let the comments/suggestions begin...
    I would also like some comments on the flow of the whole setup process!!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Very nice. This combined with Sonic's new currentcity, zip, county and state should provide a load of information for our skins. I'll take it out for a pilot shortly.
      awesomeness
      Car : 00' Chrysler 300M
      Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
      Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
      CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
        Cool. This is just what I've been looking for! Gonna try it out now...
        1997 Corvette
          looks sweet i gotta try it out
          im not running an epia but what sort of cpu usages does this take
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          [(o)______(o)]b VanPimpin'
          LostReceptions Apps D/L Here
          GPSGasoline- Rewriting
          CarPCNetwork
            Right now, not quite as much when its finished. Only CPU load is when its scanning, but that doesn't take long anyway. I have seen times from 150ms on my desktop to 2.3s on various other comps. It also depends on the length of the street names.
            After I finish, I don't really think that it will take up that much...I have kept the code as small and effeicent as possible, so that anyone will be able to use it hopefully!
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              very nice, hats off!!!
              some comments on the setup.
              the save button doesn't work, i cant click it. Using enter works though.
              Sometimes the letter that its showing me to recognize, well i cant recognize it all the time. Some of the letters are cut off so i had to guess what letter it was, leading to garbled street name in some cases. For example, ocr in red text, IG in blue
              EXIT 44B IL-9
              EXIT 44B IL-19
              KENEXNEXEDY EXPY E
              KENNEDY EXPY E
              scanning only seems to work when ig is visible, is this expected at this stage?
              Other than that, it seems to work very good.
              shouldn't the letters be the same for everybody? Just curious why you have to teach it, its not a big deal though.
              nice job
              beer replenishment fund
              mp3car live search
                Funny, I don't think that I even ever tried clicking on it, as your hands are alread on the keyboard anyway.
                Could you post a pic, so that I can see how I might address the issue.
                The only letter that I came across was 'D' on the v2/v3 reg, because of the way I have it scanning. It cuts it in half and so I just used the first part and skipped the second. Thats also why I have it display what it has scanned and understands as you go along.
                Yes, I want to get the main point of this perfected first, as the rest is a piece of cake.
                No, as I found with sonics testing, differences will creap up if you have the cleartype effect on/off as one example. And I figured that if it leads to everyone doing the learning, I'd better make it easy as poss.
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
                  Cool. Tested out and seems to run good.
                  My "save" button works.
                  When going through the "learn" process, sometimes I get "double letters", like it would show "AV" for ave, instead of doing an "A", and then a "V" one at a time. Does this makes sense? Does it supposed to do this? I guess it happened only a couple of times and everything seems to display correctly when I test it -- just wondering.
                  Seems to take about 2 seconds to get the street name on my system. Not sure how much cpu time it takes up during the process, I'll check that out more later.
                  Thanks Blue! This little app is awesome!! Can't wait to get the full version!! BTW, when can we expect it?
                  Gonna go out now and play with it a little more....
                  1997 Corvette
                    Yes, it is working correctly. The reason that you will get double letters is b/c the letters either touch each other or there is no vertical space between them. Its the way that I have it scanning, is the reason it happens, but it was the only way that I could use in order to get the kind of accurate street name results
                    There are quite a few of these: TT, RA, RY, KY, TA, XA, ect...
                    This is also why I worded the learn window text with "enter what you see"
                    Not sure, as I have only been working on this for the last two weeks, so I might say within the next two weeks, we'll see.
                    DFX 5.1.1 Skin
                    Appstore Link
                    RRMedia
                    RRExtended
                    DFXVoice
                      First post updated.
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        Well, I take it that all is well with this as no one has posted any probs...
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          works on two of my computers with intel chipsets/graphics doesnt work on my computer with an nvidia card in it. I believe there's something about the native resolutions of graphics cards that make this not work for some people. I had the same issue with my igAddon utility.
                          Live mp3Car Facebook Chat
                            What part doesn't work, all, letter learning...ect, as this really shouldn't be card dependant at all, once you teach the letter defs for your setup. On these ones that don't work, is the street font color not the same white number as the other as that is the only thing that I could really see affecting the scanning/learning. If so then I will have to change the hard coded color match to user set-able.
                            I also fixed the config to resolve the prob w/ the bars
                            DFX 5.1.1 Skin
                            Appstore Link
                            RRMedia
                            RRExtended
                            DFXVoice
                              Little Confused
                              So I have this up and running and it works pretty well for how difficult of a task this is but I have a few issues.
                              1) is there a way to make the "ocr is running" box go away or is that because it's still in beta?
                              2) is it only reading the label when ig is visible? It seems to not be reading anything when I'm in a different scren
                              3) is anyone else getting the label only showing up in the gps skin? I can get the label to show up in the same screen it is read from but can't get it to update anywhere else
