RRMobile Resurrection
  • RRMobile Resurrection
    Not sure if anyone has been actively working on this - but I've been having a good dig around the source code for RRMobile with a view to continuing support for the plugin.
    I've made a couple of simple changes to the program so far, which are:
    • Plugin starts with no default profiles configured
    • Plugin no longer closes when phone not available
    • Clicking on 'Phone Status' icon when phone not available re-establishes communications
    I am currently waiting for another BT dongle to turn up so I can actually configure/test the plugin with a view to extending it.
    If anyone out there is experienced with skins, I could use some help generating a configuration skin for the plugin...
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
    i've fiddled around with the source several times but being that my CDMA phone barely works with anything i havent gave it a real big effort. If you need any support i'm always around though
    Live mp3Car Facebook Chat
      I was on the same boat as you. Play with the source code for a while, but my interest in phone and PC drop as FreeFone emerged.
      Till now, I still don't bother configure the carpc for phone connection.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        I would LOVE for someone to figure out a decent way to interface with CDMA phones. I got my LG VX8100 to work so-so with RRMobile. That was a lot better than what I have been able to get with FreeFone.
          well the problem with CDMA phones is they use an extremely limited AT Modem command set. In order to get them fully capable of working we would need to find out qualcomm's AT command set but that isnt readily available to the public. But if anyone could find it i'd have rrmobile working with it in a snap! lol
            I'm also looking for a program that will let you make calls from the computer.
            There's a nice guide with AT commands, and Qualcomm defined AT commands at http://www.canarysystems.com/nsuppor...T_Commands.pdf. The Qualcomm ones are at Chp 19.
              Finally got my XDA Graphite (WM6) to actually communicate with ATSniffer
              I had to install some stuff on the phone to enable the DUN functionality that used to be in WM5, which then gave me the ability to add a serial port to the phone!
              The output results don't look too promising though....
              Code:
              Time	AT Command	Res.	MSec	Return
              13:56:55	AT	OK	46	<CR><LF>OK<CR><LF>
              13:56:55	ATV1Q0	OK	31	<CR><LF>OK<CR><LF>
              13:56:55	AT+GMI	OK	31	<CR><LF>Xda Graphite<CR><LF><CR><LF>OK<CR><LF>
              13:56:55	AT+CGMI	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:55	AT+GMM	OK	31	<CR><LF>SmartPhone<CR><LF><CR><LF>OK<CR><LF>
              13:56:55	AT+CGMM	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:55	AT+GSN	OK	125	<CR><LF>352421010160473<CR><LF><CR><LF>OK<CR><LF>
              13:56:56	AT+CGSN	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPAS	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CLIP?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CLCC	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CBC	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CSQ	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBR=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBR?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBS="ME"	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBR=1	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBR=1000	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBS="SM"	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:56	AT+CPBR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=1000	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS="MC"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=1	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=1000	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS="DC"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=1	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS="RC"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBR=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:57	AT+CPBS="EN"	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBS="FD"	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBR=1	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBS="LD"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBR=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBS="ON"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBR=1	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBS="TA"	ERR	15	<CR><LF>ERROR<CR><LF>
              13:56:58	AT+CPBS="AP"	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	at+mode=2	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:58	at+mode=0	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cpbs=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cpbs="AD"	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+mpbr=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+mpbr=1	ERR	15	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cgsn	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cgmr	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cgmm	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cscs=?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:56:59	at+cscs="ASCII"	ERR	15	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGMI=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGMI	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGMM=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGMM	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGSN=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CGSN	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CSCS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CSCS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CIMI=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:56:59	AT+CIMI	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:00	AT+CMUX=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:00	AT+CMUX?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:00	AT+GMI	OK	31	<CR><LF>Xda Graphite<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	AT+GMM	OK	31	<CR><LF>SmartPhone<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	AT+GMR	OK	109	<CR><LF>ASUSTeK COMPUTER INC.;XdaGraphite;V2.17.2.P9_2007-06-11;17913<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	AT+GSN	OK	121	<CR><LF>352421010160473<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	AT+GOI	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:00	AT+GCAP	OK	78	<CR><LF>+GCAP: +FCLASS<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	ATI0	OK	46	<CR><LF>Microsoft Corporation AT Command Interpreter Settings...<CR><LF><CR><LF>  E0  L0  M0  Q0  V1  X4  &C1  &D2<CR><LF>  S00=000  S01=000  S02=043  S03=013  S04=010<CR><LF>  S05=008  S06=002  S07=060  S08=002  S10=014<CR><LF>  S12=050<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	ATI1	OK	46	<CR><LF>Microsoft Corporation AT Command Interpreter Settings...<CR><LF><CR><LF>  E0  L0  M0  Q0  V1  X4  &C1  &D2<CR><LF>  S00=000  S01=000  S02=043  S03=013  S04=010<CR><LF>  S05=008  S06=002  S07=060  S08=002  S10=014<CR><LF>  S12=050<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	ATI2	OK	31	<CR><LF>Microsoft Corporation AT Command Interpreter Settings...<CR><LF><CR><LF>  E0  L0  M0  Q0  V1  X4  &C1  &D2<CR><LF>  S00=000  S01=000  S02=043  S03=013  S04=010<CR><LF>  S05=008  S06=002  S07=060  S08=002  S10=014<CR><LF>  S12=050<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	ATI3	OK	46	<CR><LF>Microsoft Corporation AT Command Interpreter Settings...<CR><LF><CR><LF>  E0  L0  M0  Q0  V1  X4  &C1  &D2<CR><LF>  S00=000  S01=000  S02=043  S03=013  S04=010<CR><LF>  S05=008  S06=002  S07=060  S08=002  S10=014<CR><LF>  S12=050<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	ATI4	OK	31	<CR><LF>Microsoft Corporation AT Command Interpreter Settings...<CR><LF><CR><LF>  E0  L0  M0  Q0  V1  X4  &C1  &D2<CR><LF>  S00=000  S01=000  S02=043  S03=013  S04=010<CR><LF>  S05=008  S06=002  S07=060  S08=002  S10=014<CR><LF>  S12=050<CR><LF><CR><LF>OK<CR><LF>
              13:57:00	AT+WS46=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:00	AT+WS46?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CSTA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CSTA?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CMOD=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CMOD?	ERR	27	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CHUP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CBST=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CBST?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CRLP=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CRLP?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CR=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CR?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CEER=?	ERR	11	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CEER	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CRC=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CRC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CHSD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CHSD	ERR	50	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CHST=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:01	AT+CHST?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CHSN=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CHSN?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CHSC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CHSC	ERR	27	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSDF=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSDF?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSIL=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSIL?	ERR	27	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSTF=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CSTF?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CNUM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CNUM	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CREG=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CREG?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+COPS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+COPS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CPWD=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CLCK=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:02	AT+CLIP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CLIP?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CLIR=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CLIR?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+COLP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+COLP?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CDIP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CDIP?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CCUG=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CCUG?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CCFC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CCWA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CCWA?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CHLD=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CTFR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CUSD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CUSD?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CAOC=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CAOC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:03	AT+CSSN=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CSSN?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CLCC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CLCC	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPOL=?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPOL?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPLS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPLS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+COPN=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+COPN	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CAEMLPP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CAEMLPP?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPPS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPPS	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CFCS=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CFCS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CAAP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CAAP?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPAS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:04	AT+CPAS	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CFUN=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CFUN?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CPIN=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CPIN?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CBC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CBC	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CSQ=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CSQ	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CMEC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CMEC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CKPD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CDIS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CDIS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CIND=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CIND?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CMER=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CMER?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CPBS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:05	AT+CPBS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CPBR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CPBF=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CPBW=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CCLK=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CCLK?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CALA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CALA?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CSIM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CRSM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CSCC=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CSCC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CALM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CALM?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CRSL=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CRSL?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CVIB=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CVIB?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:06	AT+CLVL=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CLVL?	ERR	62	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CMUT=?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CMUT?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CACM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CACM?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CAMM=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CAMM?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CPUC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CPUC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CCWE=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CPWC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CPWC?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CLAN=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CLAN?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CLAE=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CLAE?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CSGT=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CSGT?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:07	AT+CSVM=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CSVM?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CRMC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CRMC?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CRMP=?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CMAR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CLAC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CLAC	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CALD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CAPD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CTZU=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CTZU?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CTZR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CTZR?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CPROT=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CGLA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CRLA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CCHO=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CCHC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CEAP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:08	AT+CERP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+CERP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+CMEE=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+CMEE?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+FCLASS=?	OK	31	<CR><LF>(0)<CR><LF><CR><LF>OK<CR><LF>
              13:57:09	AT+FCLASS?	OK	31	<CR><LF>0<CR><LF><CR><LF>OK<CR><LF>
              13:57:09	AT+VBT=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VBT?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VGR=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VGR?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VGT=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VGT?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VIP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VIT=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VIT?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VTS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VTD=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+VTD?	ERR	15	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+CSMS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:09	AT+CSMS?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CPMS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CPMS?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CMGF=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CMGF?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CESP=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSCA=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSCA?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSMP=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSMP?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSDH=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSDH?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSCB=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSCB?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CSAS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CRES=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CNMI=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CNMI?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CMGL=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:10	AT+CMGR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CNMA=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGS=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMSS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGW=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGD=?	ERR	27	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGC=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMMS=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMMS?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGL=?	ERR	46	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGR=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGS=?	ERR	31	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGW=?	ERR	93	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CMGC=?	ERR	35	<CR><LF>ERROR<CR><LF>
              13:57:11	AT+CNMA=?	ERR	50	<CR><LF>ERROR<CR><LF>
                *SNAP*
                Hmmmm, not working yet..............
                Leonardo Da Vinci
                  Phonebook mode
                  Unfortuneatly I have no idea how to implement this, but on the Alltel Razr V3M, I can open hyperterminal, send the command AT+MODE=2 and the phone starts to react the way these phone controlling programs want. http://en.wikipedia.org/wiki/Motorola_Phone_AT_Commands
                  This is where I came up with the idea. I've only tested this in Freefone, and it still has a few hiccups.
                  Can't think of a single cool thing to type here........
                  Progress:
                  Hardware:
                  Parts Acquired: 90%
                  Configured: 50%
                  Software: Not Even close!!!! Looking for a good phone software solution
                  Fabrication and Install
                  Screen Mounting Figured Out!
