RRMobile 0.3 Development
  • RRMobile 0.3 Development
    I guess this has died too.... When oh when will we get a phone plugin that actually works? I'd pay $100 for the program at this rate! its just too long overdue... the technology is there, it just needs a genious to hack it apart and make it work.
    Although I don't actively have a phone working yet (left mine at home today!), I've started making some fairly heavy changes to RRMobile with a view to providing an update in the near future.
    The full list of changes that I have made so far:
    • Modified plugin structures to be class based (for transportability of data across the application)
    • Plugin configuration INI file reader re-written
    • Plugin configuration modified to read from a single file
    • Plugin starts with no default profiles configured
    • Plugin now writes a default configuration if none exists
    • Plugin no longer closes when phone not available
    • Plugin loads demo data of 100 contacts with random default numbers, when Com Port = 0
    • Clicking on 'Phone Status' icon when phone not available re-establishes communications
    The new configuration file looks a little something like this:
    Code:
    [Configuration]
    RRMSkinPath=C:\RoadRunner\Plugins\RRMobile\Skin\
    RRMLogLevel=0
    AvailableProfiles=1
    ActiveProfile=1
    [Profile 1]
    Com Port=0
    Baud rate=57600
    Timeout=5
    Use DTR=0
    Use RTS=0
    Wait Time=3
    Supported Commands=
    Unsupported Commands=
    Initialise Command=
    Vendor Command=
    Model Command=
    Call Answer Command=ATA
    Call Hangup Command=ATH
    Call Dial Command=
    Last Phone Book=0
    [Profile 1 \ Phone Book 0]
    Phone Book Name=Phone Book 0
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 1]
    Phone Book Name=Phone Book 1
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 2]
    Phone Book Name=Phone Book 2
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 3]
    Phone Book Name=Phone Book 3
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 4]
    Phone Book Name=Phone Book 4
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 5]
    Phone Book Name=Phone Book 5
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    I'll probably tidy up the names of the sections related to the phone books so they read a little more sensibly (ie Profile 1 \ Outlook Phone Book etc) and I'm going to see if I can get my hands on some old working mobiles for testing with.
    If you have RRMobile working currently, I'd appreciate a copy of your existing configuration files for a couple of reasons:
    1) To write a conversion routine to port over existing configurations
    2) To build a list of commands on a phone by phone basis to provide some basic templates to get people up and running quicker
    Anything you can provide, please e-mail me here!
    TIA.
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
      Demo screenshot of some demo data enclosed:
        Originally posted by Enforcer View Post
        Pulls out chair and sits down.
        Looks around but is disappointed as there is no sign of the blonde waitress from the other thread.
        One step at a time, I want to get a grip on what RRMobile is doing to then use it in a completely clean app.
          Just fixed a bug causing the plugin to hang when communicating with some phones.....
            Really looking forward to your release.
            If you need any testing done I'm happy to help out (I have a Sony Ericsson W610 & HTC Wizard - WM6)
            Will this be able to route audio through the PC (and pass the pc's mic as an input) as I've currently found nothing able to do this
            Cheers!
              This plugin isn't likely to be able to connect to the Audio Gateway (the bit that passes the audio over BlueTooth), certainly initially.
              I intend to write a new plugin where hopefully this will be achievable, although I'm still researching the subject. If I can prove the concepts further than I've gotten so far, then I'll expose the back-end of the new plugin to a new version of RRMobile.
                rrMobile relives
                Cheers!
                Riderunner / Genesis
                Wifiman_NET:Version 1.0.0
                  Excellent, thanks for your reply - I look forward to seeing how this develops!
                    i'm in to!!
                    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                    RRTube ==> [View/Download Youtube Videos]
                    WifiMan ==> [Wifi Manager]
                    RRec ==> [Audio Capture]
                    If You Want To Be Given Everything, Give Everything Up ...
                    Bird York -- In The Deep --
                      Just to add a little encouragement. I'm watching this thread too.
                      Y2K Accord Dell GX150
                      EmoRebellion is a SCAMMER
                        me dos. phonecontrol is not working on any of my computers.... im anxious for a new [supported] solution
                          Subscribed!
                          Christmas Car Project 2008
                          ArrowDash Skin Worklog
                            Wow! Great news for sure! CDR took the code and went flash with it Meaning it can not be skinned. I have been hoping someone would take the code and leave it as it was originally written to work directly with RR's skins. Great work!
                            My Fiero Build Thread
