Skinners Helper and Debugging Tool By:JohnWPB & BlueZX3 [ Updated 12/05/08 ]
  • Skinners Helper and Debugging Tool By:JohnWPB & BlueZX3 [ Updated 12/05/08 ]
    New Version v1.7 12/05/08
    - Re-Noted: getting indicator status
    - Re-Noted: logging of these clicks: Indicators, *Slider's (name and value(0-65xxxx))
    - Fixed control painting ( was leaving some artifacts )
    - Added "SkinTool_LogOn","SkinTool_LogOff" for turning on/off the live log instantly
    - Fixed bombing issue when using the AutoUpdate feature (now req's the dll to be used)
    Ver 1.5 09/19/08
    - remember the window locations from the last time that it was ran.
    - copy text from the degub log
    - Auto Update Labels / Variables
    - Ability to re-execute commands directly from the debug log by selecting and right clicking the command in the list
    - Ability to have the debug log in a separate resizable window (As seen in the screen caps below)
    - Remembering of any/all entered items
    - New "Edit Skin" button
    - New Dll file to coincide with the latest RR Build
    This is not an "end user" plugin by any means. It however is a tool to help when creating skins & debugging Road Runner problems. It is a simple way to see variable & label contents, as well as to set them to test skins in Road Runner.
    Instructions:
    Send Command: (The top 3 lines) are for sending commands directly to Road Runner. 3 lines have been provided to keep most used commands you are testing available with just one click.
    Restart RR: Does a complete shut down of Road Runner and re-starts it.
    Reload Skin: will reload the current skin to check any changes that you made.
    Reload Skin +: Same as Reload above, however this will return you to the skin that Road Runner is currently on, and not back to the main menu.
    Variable / Label Radio Buttons: Select either Label or Variable, Type the variable name, without the quotes or dollar signs, and press Get Contents, and the contents will be displayed .
    NOTE: Check marking "Auto Update" will automatically update the information whenever the label / variable changes in RR. The blue indicator you see in the screen capture below blink when the variable / label is set to auto update.
    Minimize RR: Minimizes RR to the task bar.
    Clear: Clears the current log file displayed on the screen (Added by BlueZX3)
    Pause Debugger: This will start and stop the debug text from scrolling automatically when viewing it. (Added by BlueZX3)
    Save: Save the debugging text to a file (Added by BlueZX3)
    Tabs at the top: To switch between the main window and the live debug. On the live debug window, you can also click "Separate Window" to show the live debug in s separate window.
    My Fiero Build Thread
    very nice little helper plugin. I'm gonna get some use out of this!
    Live mp3Car Facebook Chat
      So nice.
      I could have really used this when I was developing MMI, but it'll definitely help with my new skin.
      Thx!
      Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
        Yes, it is skinnable. See the Top menu bar, how it is transparent on my XP System
        Has anyone found any problems or suggestions. This was literally tossed together in about a half hour. I am sure there are something I may have overlooked that could come in handy.
          So far so good.
          Here's a suggestion:
          - List/DL highlighted item properties (postion, DLPATH, TRACKPATH, etc.)
          - More LABEL & VARIABLE slots like the "SEND COMMAND" buttons.
          Seems like you have the real estate for it.
            Ooooh...and how about a status window that displays information like the debug.txt file only it is generated during runtime so you can see what RR is doing?
              I like this...a big time saver...a debug window would be even better, not complaining though, as this is a nice tool.
              CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
              MediaLaunch for RR
              Online Check for RR
              Locker for RR
                I take it that you never seen my live debug win plugin? It makes it a ton easier to see typo's and why something didn't work.
                John asked if the two of these could be combined or at least be able to use the data that mine shows in the bottom of his util.
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  Very nice, just started using it testing my skin changes
                  CarPuter Progress:
                  Planning:-----> [||||||||||] 100%
                  Hardware Buying:-> [||||||||||] 100%
                  Software:-----> [||||||||||] 100%
                  Installing:-----> [||||||||||] 100%
                  Current Project= Making skins in photoshop...
                    John will be making an update to this util. The new one will incorperate my live debug log into it be make it a really more complete skinning/ debuggin util.
                    DFX 5.1.1 Skin
                    Appstore Link
                    RRMedia
                    RRExtended
                    DFXVoice
                      Other suggestions:
                      -Instead of having to hit the "GET LABEL/VARIABLE" button, the label/variable in the input box will update automatically in the util whenever it changes w/in RR?
                      -MINIMIZE RR button on the util <- useful when trying to get to something on the desktop that's behind RR
                        Originally posted by Sal R. View Post
                        Other suggestions:
                        #2 Was part of the updated util already, as its a must have..
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          Not trying to impede on your efforts. This is just me messing around trying to learn AI's GUI function.
                            would be nice to have 3 buttons, next / prev / reload screen, those buttons would load a virtual screen with all the values loaded in place. that way people wont even have to load any screen in RR. make changes in the .skin and see them right way.
                            BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                            RRTube ==> [View/Download Youtube Videos]
                            WifiMan ==> [Wifi Manager]
                            RRec ==> [Audio Capture]
                            If You Want To Be Given Everything, Give Everything Up ...
                            Bird York -- In The Deep --
