OVERLAY [screen loader]
  • OVERLAY [screen loader]
    this is a very simple script that is capable to load any screen(.skin files) just like RR does, the big difference is that the background is not used, some people including myself needed this. heres some screenshot. same screen loaded using this little guy(top) and RR (bottom).
    as of now only buttons are supported (is what i needed the most)i might include labels and indicators later on...
    NOTE:skin(Teknik V2 created by valheru) hope is ok to use it as an example)
    [[[labels enabled in BETA version]]]
    1.25 out, memory leak and cpu usage fixed
    1.3 out, RideRunner/RoadRunner Version
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
    Very nice.
    I can already image the possibilities in my new skin...
    I know you can achieve the same effect using pink transparencies, but for some reason, I could never get that to work properly.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      another big advantage using this is, that even if a screen is loaded on top of RR you still have control over RR, not possible using RR for the moment.(i think guino said something about adding this features to RR in upcoming releases not sure.)
        Overlay in MKIII
        I have this app in My skin on Destinator 7 works really well, slight delay in the button press.
        but its the best so far.
        in my D7 i have 2 OL graphic files 1 for map view , then you hit on/off button which will switch to the 2 image OL. so the menu's of D7 can be used .
        Riderunner / Genesis
        Wifiman_NET:Version 1.0.0
          I wonder if an image can be overlayed on top of a visualization? That way i can have buttons for next and prev vis right on top of the visualization itself. I'm going to have to try it!
          Thanks El C.
          OLD SYSTEM (DEAD)
          Intel D945GCLF2 Dual Core ATOM
          Lilliput 7" 629GL 2008 LED Backlight
          BU-353 USB GPS Receiver / iGuidance / IGO8
          M2-ATX Power Supply
          RideRunner Front End / Various Skins
          Windows XP SP3
            well now - I could hardly refuse you the use of TEK2 ... seeing as you put so much work into it's creation ...
            The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
              wow.. great job El.... This could allow gps view with tremandous improvement if i understand correctly.. carputer1 just inspired me what i wanna do with my gps view...
              basically, we can now put the buttons on the map as floaters and make them look transparent... Is it possible you can put a timer and make the skin go away? you know like valheru's popup..
                This is Fantastic! It does load over the vis, those buttons actually work for prev. and next avs. Now i only have to go dig into skincommands to learn how to position the overlay.
                Thanks El Camino, there's a lot that can be done with this.
                EDIT: nevermind the position, i loaded it in the truck and the buttons show where they should.
                OLD SYSTEM (DEAD)
                M2-ATX Power Supply
                Windows XP SP3
                  i'm glad you guys have found a good use for it, this is based in what i did for the carwings skin. part of the code belongs to LiquidSmoke, thats what i heard.
                    Nice work EL - Downloading now, AutoIT I take it?
                      Question
                      I want to overlay buttons on the GPS screen and also the main menu screen but the overlay buttons for each screen are in different positions..can that be done? if so, how?
                      OLD SYSTEM (DEAD)
                      M2-ATX Power Supply
                      Windows XP SP3
                        you need
                        to make the png's with the buttons where you want to see them.
                        this is how i did it for the gps scr in my skin.
                        you also need to have a seperate cmd line for the other images
                        "C_OVERLAY","RUN;$rrpath$Plug in's\Overlay\ElcosMenu.exe|overlay2.skin"
                        "O_OVERLAY","RUN;$rrpath$Plug in's\Overlay\ElcosMenu.exe|overlay.skin"
                        1st line gps map on overlay png
                        2nd line gps menu overlay png
                        hope that helps
                          hope that helps
                          Sure does help.
                          This is the command on the main menu to start visu and an overlay for next prev avs:
                          "RUN;$SKINPATH$ElcosMenu.exe|overlay.skin||VIS U"
                          So to start and overlay the GPS screen (from a button on the main menu) i could use:
                          "RUN;$SKINPATH$ElcosMenu.exe|overlayGPS.skin|| GPS"
                          I get it! Thanks very much.
                          OLD SYSTEM (DEAD)
                          M2-ATX Power Supply
                          Windows XP SP3
                            Thanks El Camino!!
                            worked great for Ig4...couldn't get it to look good over video, it just flickers, probably just my on-board graphics though...
                            here's a SS of My IG4 screen with the overlay
                              this is a down fall
                              for OL , it dose not like video, nor dose it like being over ilists, theses are the only 2 things that i have found with this app so far.
                              nice Ig Ol skin
