Silabs no RDS?
  • Silabs no RDS?
    Dear All,
    Just recieved my Silabs FM USB.
    Plays no problem etc but the RDS doesnt seem to do anything, just a scrolling message about silabs.
    Any help?
    maybe you should have a look at this thread
    Cold weather mobo list: Copy the list and add your board
    my hidden screen in action (youtube) , the worklog , RR Volvoskin
      or you could look here , as the plugin in the post above is very good, but the 1 in the link below is the latest ver. and the 2 aurthors are helping each other to make a final plugin. have a look here i'm use it now very good.
      silabs plugin
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        He that one is new for me, thanks for the link
          I did all in the post and its crashed it all now
          All I get is the iceradio skin comes on, no radio works.
          If I run silabs on its own without roadrunner it works
            did you register the testsilabs.dll
              Yeah and it went through ok.
                mmmm ok i had no problems with it worked straight off, which ver.dll are you using as it has been updated alot through out the thread, i take it you D'led the test skin, of which has iceradio and spider's skin in there you should get spider's skin up 1st the iceradio skin is just bits that have not been put into spider's skin yet.
                what skin are you trying to intergrate it to. and where did you put the files and register, and what ver of the dll have you got.
                and i'll help you along
                  Hi,
                  I downloaded the 1.8.5.6 dll.
                  I have the BMW IGO8 skin with the ICERADIO skin added.
                    I have just noticed that the "WAVE" slider is on zero and will not move on any of the skins I load?
                      ok i take it your useing the origanal iceradio skin , and i take it you had or still have the iceradio plugin, if this is the case the dll from spider will not work all the cmd's are different, and nothing will work.
                      i can send you my skin file, but you will have to play with the positioning of the code and graphics, but it all works, and make sure you have X,testsilabdll in your menu.skin.
                        Yeah that would be great, thanks a million!
                          here you go just remove the .txt from the name
                            Cheers!
                            Wll do it now.
                            Anything I should clean up, change?
                              there's nothing in the that use's the exectbl just add a graphics to the 3rd line on/off
                              and move stuff about in editor.
                              add X,testsilabs.dll to your menu.skin
                              remove anything to do with iceradio
                              download this ver. http://www.mp3car.com/vbulletin/1225707-post35.html
                              put into rr root and register.and you should have a TestsilabdllConfig folder put that in rr root.
                              download this .dll http://www.mp3car.com/vbulletin/1225756-post38.html put in rr root
                              and you radio start cmd to this RADIO||sil_start
                              and all should be good
