All plugins need updating
  • All plugins need updating
    GUINO has fixed the Indicator in plugins, to do that
    a change has to be made in the main code to allow
    a non processed Indicator...
    this is the solution we came up with, and adding of the ReturnIndicatorEx
    which depreciates ReturnIndicator
    change your code to the default return of "" instead of "False"
    example
    Code:
    Public Function ReturnIndicator(IND As String) As String
        'Default (No Action)
        'ONLY return "True" or "False" IF AND ONLY IF you process that code
        'else return ""
        ReturnIndicator = ""
        Select Case LCase(IND)
            Case "myindicator"
                ReturnIndicatorEx  = "True"
        End Select
    End Function
    also... TO MOVE FORWARD change ReturnIndicator to ReturnIndicatorEx
    ReturnIndicatorEx:
    Code:
    '* This Function will be called with requested indicator code
    '* specified at the skin file. Simply return "True" or "False" to
    '* displayed the respective ON or OFF layer of the skin images.
    '* alternatively you can specify a path to a file to be displayed
    '* as the indicator specified. Return "False" to erase the image.
    '* ONLY return something else IF AND ONLY IF you process that code
    Public Function ReturnIndicatorEx(IND As String) As String
        ' DO NOT RETURN "False" for unprocess indicators, return ""
        ReturnIndicatorEx = ""
            Case "myindicator"
                'This example show ON for even seconds and OFF otherwise
                ReturnIndicatorEx = IIf(Val(Format(Time, "SS")) Mod 2 = 0, "C:\VBStuff\Road Runner\XMArt\1.gif", "False")
            'Specify whatever and whichever indicators you wish to create
            'You can add as many as you'd like, and you can process complex indicators as long
            'as you parse them yourself (i.e. "mycomplexindicator;parameter")
            'Case "myindicator2"
                'Insert Code here to return "True", "False" or Path name
        End Select
    End Function
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    I will prob post my C# plugin template i did at some point
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      it says there in the notes.. but i wanted to point out the addition to the indicator code. Plugin indicators can now be true, false, OR an image path. This will allow you to display an image through an indicator.. similar to the way the ALBUMART indicator works. To display the image simple create an indicator and set the case for that indicator to ReturnIndicatorEX = IMAGEPATH.. like so
      Code:
      Case "myindicator2"
                  ReturnIndicatorEx = ImagePath
      'where ImagePath is a full path to image file stored locally
      to remove this indicator from being shown simply
      Code:
      ImagePath = "False"
      Live mp3Car Facebook Chat
        mitch
        Would appreciate that.
        1.9in x 2.9in -- 47mm x 73mm
          Code:
          Case "myindicator2"
          Code:
          ImagePath = "False"
          This is in fact a great improvement as the same indicator code is not limited to just On/Off states, but it can be expanded to many different states displayed each by a different image... an example would be the channel arts for XM/Sirius etc.. where the Album art is an indicator and the image of channel is just a different state for the indicator. Not to say, the images will be loaded with transparency over the OFF layer.
          Ride Runner RR's Myspace
            Mitch, in your example above you do have the code correct, but in the comments it states:
            You may want to change that, as if they read the "instructions" in the code, it would defeat the "" instead of "false"
            My Fiero Build Thread
              i'm lost on that one. You can still set ReturnIndicator to False, you just cant set it as false as the default setting. Where ReturnIndicator = "" used to be ReturnIndicator = false. That was pretty much the root of the problem
                no ReturnIndicator still works fine as long as the default isnt set to false. That being said ReturnIndicatorEX is EXACTLY the same accept for the image improvement
                  Has been fixed also this issue?
                  _______________________________________
                  Car installation 95% [■■■■■■■■■■■■■■■■■■■]
                  Current project: Parking sensor USB interface
                    there is no issue
                    if not proccesing a slider return a -1
                    mitch
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      bump for c#...
                        You have me lost at "accept for the image improvement"? What Image improvment? You could always set a path to be displayed, since....IDK.
                        Next in line: RRMedia v2.0
                        DFX 5.1.1 Skin
                        Appstore Link
                        My RideRunner Plugins
                        RRMedia
                        RRExtended
                        DFXVoice
                          Originally posted by 2k1Toaster View Post
                          bump for c#...
                          It's C#'s birthday, how old?
                          I was thinking this, but thought I had already given mitch too much of a hard time to mention it.
                            you could always set a custom image path to for an indicator in the extension interface? Thats news to me.. i thought it was an ON/OFF thing only before.
