Microtech Dash AutoIT Script
  • Microtech Dash AutoIT Script
    Hi All,
    For those of you who have a Microtech computer for their engine management I have created this little autoit script which just grabs the values from MTDF (MicroTech Dash Free) and sends them to RR as labels.
    INI Explained.
    Code:
    [Window]
    windowName=cvt's MT Dash Free v0.2a     -   cvt: [email protected]
    [Class]
    CUSTOMMICROSTATUS=WindowsForms10.EDIT.app.0.378734a2
    CUSTOMMICRORPM=WindowsForms10.EDIT.app.0.378734a10
    CUSTOMMICROLOAD=WindowsForms10.EDIT.app.0.378734a9
    CUSTOMMICROAFR=WindowsForms10.EDIT.app.0.378734a13
    CUSTOMMICROTIMING=WindowsForms10.EDIT.app.0.378734a8
    CUSTOMMICROWATERTEMP=WindowsForms10.EDIT.app.0.378734a6
    CUSTOMMICROTPS=WindowsForms10.EDIT.app.0.378734a7
    CUSTOMMICROVOLT=WindowsForms10.EDIT.app.0.378734a12
    CUSTOMMICROAIRTEMP=WindowsForms10.EDIT.app.0.378734a5
    CUSTOMMICROINJECTOR=WindowsForms10.EDIT.app.0.378734a11
    [Click]
    connectclass=WindowsForms10.STATIC.app.0.378734a2
    [Settings]
    wait=500
    connectonopen=1
    windowName is the name of the MicroDash Window
    Each item under the [CLASS] section starts with the RR Label name followed by the ClassNN name of the control to read.
    connectclass is the ClassNN name of the "Connect" button control.
    wait is the time in ms to wait between updates
    connectonopen is wether it will try to click the connect button on the application (1=yes, 0=no)
    To use this you will need MicroDash and have it launched before this script.
    Once the script is executed it will check if the "WindowName" is open (will end script if it isnt) and then send the following labels to RR.
    CUSTOMMICROSTATUS
    CUSTOMMICRORPM
    CUSTOMMICROLOAD
    CUSTOMMICROAFR
    CUSTOMMICROTIMING
    CUSTOMMICROTPS
    CUSTOMMICROVOLT
    CUSTOMMICROAIRTEMP
    CUSTOMMICROINJECTOR
    PS Microdash seems a good application to embed into RR for gauges etc.
    ToDo:
    Add low/high alarm values
    Create skin to embed MicroDash and for Values
    Make script automatically connect MicroDash
    Changelog:
    MTDF2RR v1.1 - Released 16/9/2008
    *First key of class item in ini file is the RR Label
    *Option to connect to MTDF on open
    *Removed alot of doubled code.
    MTDF2RR v1 - Released 15/9/2008
    *First Release
    http://mukow.photomontages.com.au/in...ge=rrmicrotech
    Tim
    Some FYI..
    You might want to change the custom labels to use a "CUSTOM" prefix instead of the "!" b/c it might be easier for skinners or anyone wanting to incorporate into a skin. An example would be a flash based skin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Originally posted by Blue ZX3 View Post
      Some FYI..
      Thanks Blue,
      Noted will be changed in next release.
      is it just eg. CUSTOMMICRORPM ??
        v1.1 added
          Updated download link
