Cell Phone Bluetooth CallerID for CarPC
  • Cell Phone Bluetooth CallerID for CarPC
    Ok new project is comming up. I want to create the Caller ID project for carPC and with extensive RR integration. Curent ideas is to pull out the phone number, address book name from adress book on the top screen if we get the call on the cell (so i dont have to go in my pocket to see whos actually calling) aditional functionality is to provide fullu customoizable "ring" tones for address book or text to speach to read names... you see the problem is that if you have Russian or other not standard english name the TTS (Text to Speach) so the way around that to create custom ring tones where you can assosate the the sound file or record the speech (spoken name)...
    Aditional functionality is possible such as dialing the #, text messaging etc. full controll of the phone..
    I ordered Bluetooth adapters for my developing machine the dongles will array on tues.... so first betas are comming soon
    Progress Edit
    I have compiled my base engine for extracting caller id info... it just a concept demo yet.. as I mentioned my phone broke so cand develope till i fix it, but id some one wanna play around you shoyld be able to see how it can show caller id info on our desctop. If it doesnt work let me know. For now there is no design of the app... i only did coding as rough draft.
    Pre-pre-pre Alpha release !
    New Update: Posted concept art ... well technically working program but not linked to the actual BT program
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
    This will be cool, however what'll find out is that most phones vary A LOT between each other in regards to features and command set available to control/monitor them. Feature wise, most SonyEricsons are great, most Motorolas suck. Still, whatever you build (likely to the type of phone you use) will be very usefull for those with similar phones.
    Ride Runner RR's Myspace
      well i have smarter idea, the controll sets will be stored in text file... in the folder that is nabed by the phone model name. so if your generic phone comands do not work we could look in the folder for custom commands... and is fome one has unique phone they can add their comands if they find them on the net. so scalability is not the issue...
      what my problem is that when u initiate the connection to the phone it asks to autorize connection by pressing "OK" button.... i dont lilke that , i want automatic cnection to the phone when u are in the car. For that I think I need to get hands free profile or somethig. All new cars can access your phone w/o autorization (well u need to enter pin code once) so i wonder how that works
        If any help is needed, I'd gladly offer my services. I've been wanting to have this feature for quite a while now.
        I have a Verizon Wireless LG Dare and this BT adapter, along with some programming background.
        2003 Mazda 6i Sedan - White
        CarPC in the making!
          Yea angel120 you can join my efforts on developing this. I see you are also local (i'm in Brooklyn NY)
          What programing language do u use, are u good with hardware communications programs?
          so I can use u too see if the things are wotking on your phone the same way as mine. How about you try to see if you are getting CLID data from your phone in forst place. So get our com port debugger app at COM PORT DEBUGGER then connect to your BT COM port and call yout phone you u should get somethig like"
          RINGING
          +CLIP 212100000
          RINGING
          +CLIP 212000000
          if you dont try to sens command "AT?" no queotes
            Im interesetd in helping out. I know VB.net Learn everything pretty quickly though. I have Visual studio 2008. I will be getting Verizon Samsung Glyde.
              Ok its nice that ppl have interest in the project.
              I have core code writen alredy, but since yesterday my phone decided not to send CLIP data... so I will do some reserch wh that happaned and when i'm done we can talk about how we can take parts in te project to get the max efficiency.
                RINGING
                +CLIP 212100000
                RINGING
                +CLIP 212000000
                Let me know what you need me to test out, and I'll be glad to do so.
                What part of Brooklyn? I'm off exit 25 on the LIE.
                I'm a CS major @ Queens College. I've learned C++, Java, and MIPS Assembler. Though my programming skills are elementary, I'm a quick learner. I prefer dealing with hardware and the like. My desktop has Vista, my laptop has Ubuntu with a VirtualBox Windows XP, and my carpc has XP.
                When I get back home, I'll try the COM port debugger on my desktop (I'm on campus right now).
                  I'm in Sheapsheadbay about 45min from u.
                  Hardware knowlage is good... i'm still looking for some one who knows how to work with USB protocol
                    Alright, I've been playing around with the BT stuff for a little while now. I'm able to send a picture to my phone from my PC (Vista) via bluetooth, but my phone seems to simply hang on the "Receiving Data" screen, even though my PC says it's finished. CORRECTION: I did get the picture.
                    I didn't download any different BT stacks, so I'm only using the one that I believe is native with Vista.
                    I tried the COM Debugger, and there was simply no response. I called my cell phone, no output. I dialed from my cell, no output.
                    Not sure if this helps, but the Bluetooth Version on my cell is 2.1+EDR
                    Your program hangs when I set it to COM10 @ 115200 and put in ATD####### (# = phone number).
                    Here are a few screenshots:
                    Would you know if there are any Linux programs similar to the one you linked me to? I might have better luck with that..
                      You posrt is COM9
                      The COM10 is incoming connection and it is used if the phone had initiated connection (it is imposible to initiate connection from phone though unless we would start listen to the port at the same time connection is established)
                      Any way try port #9 and use default 9600 baud rate
                      and i would reccomend to take out ur lass pix as it has you mac address, you dont want me to hack you phone, do u?
                        as to the linux part here is the link http://cutecom.sourceforge.net/ we did not write it but it is alnost identical product ... technically you can use terminal window to get access to poerts but I firgot the commands
                          i found out how to auto connect phone to pc when the devices come to distance of each other, here's how:
                          right click on the bluetooth icon in the task bar, click on advanced configuration, then click on the local services tab, then highlight the serial com port and click on properties, now just check the box that says "start up automatically" and uncheck "Secure Connection". now just remeber to always allow connection to your phone from the car pc, my phone (sony ericsson w300i) after i add a bluetooth device asks me how i want to treat the new device, if i want to always ask to connect or if i want to always allow connection.
                          this worked for me everytime i get into my car i just turn the key and everything is automatic, just make sure you don't let your friends borrow your car, i did and when my friend was dropping my car off to me at work he said the music suddenly stopped the screen said "phone call" and all he could hear was m girlfriend saying "hello, hello".
                          also take a look at my sig there is a tutorial on how to setup the audio gateway with widdcomm drivers
                          Scion CarPC
                          Bluetooth Audio Gateway Tutorial
                          How to speed up boot with buried features in msconfig
                            Actually I found something similar too
                            The auto connect is a part of the Toshoba BT stuck ... but also you have to "autorize" your comp on the phone too, otherwise you will need to confirm connection all the time ;-)
                            I wilsh i would know how to undo all the settings on the phone so my CLIP caller ID would start working again
                              isn't there a master reset? my ericsson has one, by the way just a quick heads up if you have a verizon phone loaded with their firmware your project just got a lot harder
                              Scion CarPC
