Help with using "CLLINES," custom lists and extension plugin...
  • Help with using "CLLINES," custom lists and extension plugin...
    So I have a text file that has path and filename information on it that contain attributes that I want to display.
    i.e.
    path and file #1...
    path and file #2...
    path and file #3...
    path and file #4...
    etc.
    I have no problems reading the file or displaying the information I mine from it.
    My problem I have is in trying to display such a large list into a custom list RR. The process of gathering the data from each file is slow and hangs RR until the reading/mining operation is complete.
    I need help putting together code so that my plugin only reads data based on the line height of the custom list and list position. This way the file read/data mining is limited to only what is displayed.
    When you page up/down, plugin reads the LISTPOS and CLLINES to run a loop to read the appropriate files, extract the info, and display it appropriately in the custom list.
    I've been at this for a couple days now, but just can't wrap my head around it.
    Help?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    So, I've been pouring over the old RR source code to try and understand how playlists are loaded/updated.
    The problem is, I can't quite...find it.
    I've checked modRoadRunner.bas and frmSkin.frm.
    Can someone please point me in the right direction?
    Thx!
      Found it and figured out a solution to my problem. It's a real hack job, but it works.
      Yay me.
        and the solution was.......????
          lol
          Didn't think anyone was interested, but here you go:
          Code:
              Dim i_listpos As Integer ' \\ Current CL listpos
              Dim i_numlines As Integer ' \\ "CLLINES" RR Label
              Dim i_listmax As Integer ' \\ "CLMAX" RR Label
              Dim list_start As Integer
              Dim list_end As Integer
              list_start = i_listpos - Int(i_numlines / 2)
              list_end = i_listpos + Int(i_numlines / 2)
              If list_start < 1 Then
                  list_start = 1
                  list_end = i_numlines
              ElseIf list_end > i_listmax Then
                  list_start = i_listmax - i_numlines
                  list_end = i_listmax
              End If
              ' \\ Loop until all displayed lines have been updated
              For i = list_start To list_end
                 <Insert the code you want to loop here>
                 RRSDK.Execute ("CLSET;" + CStr(i) + ";" + <Upated List Item Description>)
              Next
          Run this sub when you page down to update the list that is displayed only.
          It was simpler than I thought.
          Go figure.
            did you try writing a file in the format that works with CLLOAD/CLSAVE ? CLLOAD should be able to load/display the information quite faster than using CLSET/CLADD individually... however, if writing such file would take a relative amount of time, then your way is probably best.
            Ride Runner RR's Myspace
              Yeah, I did. That was not an optimal solution.
              What I'm doing exactly is reading ID3 tag data from the paths/filenames in an .m3u playlist and displaying them in a custom list. Having the plugin read a pl with thousands of entries and then loading it into RR is slow.
              In a nutshell, I replicated an audio player playlist function to be used w/ .m3u playlists so I can properly see the contents of a selected playlist without having to load the playlist first.
