How to do tell an indicator to turn on/off after a predetermined amount of time?
  • How to do tell an indicator to turn on/off after a predetermined amount of time?
    Here's the skin code I'm currently using:
    Code:
    SETIND;CUSTOM_IND01;ON||WAIT;5||SETIND;CUSTOM_IND01;OFF
    The code above works, but the problem with it is that the "WAIT" portion of the command. Until that portion is completed, RR queues all other incoming commands.
    How can I achieve the same thing above, but allow RR to continue processing commands commands while the timer is running down in the background?
    I've set up an AI script to run in the background that does what I would like it do it, but was wondering if there way to do it via plug in or just plain RR skin code.
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    write a script with a sleep command
    autoit example
    $RR = ObjCreate("RideRunner.SDK");OPEN RR FOR COMMUNICATION
    sleep(500) ; PAUSE TIME IN MS
    $RR.execute("SETIND;CUSTOM_IN01;OFF") ; SETS RR INDICATOR OFF
    exit;END OF SCRIPT
    New Age Garmin - Skin for RR
      This is the only I can think of with out having RR que anything. Somthing has to be done out side of RR.
        Yeah, I've got that setup already.
        I'm hoping there's away so that I don't have to use another AI script.
          The only thing you could do right now is set a timer event and use a variable to count the time.. but it would not work well between different screens unless you used a timer everywhere... I am planning to make a "timed" command of some sort.. perhaps for next release..
          Ride Runner RR's Myspace
            yeah i was about to suggest a timer as well...
            timer with a byvar toggle/flip-flop
            Planning: [|||||||||-] 90%
            Purchased: [|||||||||/] 99%
            Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
              That'd be nice. One less AI script sitting in my folder...
                The timed command support is implemented for next release.
                  I do see that no one around here reads... I have global timers in RRExtended...
                  One Shot or repeating...chsssss..
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    The way I implemented it is not really a "timer" per say, but a way to execute any command (or set of commands) after a specified time, non-reoccurring unless you issue another (or the same) timed command. A rather simple and humble approach compared to all that's in RRExtended.
                      Wow...totally missed that feature...
                        I don't make this stuff up so that it doesn't get used or b/c I have absolutely nothing better to do with my time..
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
