Execute command from my plugin only into a screen
  • Execute command from my plugin only into a screen
    Hello,
    I'm developping a plugin...
    My plugin have a timer which every 6 seconds calls a method to
    update a custom list
    I would execute the function only if the user is viewing the
    screen where the custom list is located.
    How I could obtain this?
    The first RR SDK example made shows you how to retrieve the current screen in RR -- basically you just read the "RRSCREEN" label code (i.e. RRSDK.GetInfo("RRSCREEN"). You can use this info to check if you're really on the desired screen before doing anything else.
    Ride Runner RR's Myspace
      ok, I have found this workround...I thought that there was a way to enable or disable the plugin
      I thought at sometinghs like: LOAD;MySkin.skin||ENABLE;MyPlugin
      I wouldn't hard code the name of the skin if it is possible...
      thanks
        Hard coding the name of the skin tends to keep skins cleaner in general, but if you don't want to do that, you can certainly make a command in your plugin to do what you want -- there's no limitation in that regards when making extension plugins.
