RRVoiceControl-Beta Complete: Check Released Plugins Section
This topic is closed.
  • RRVoiceControl-Beta Complete: Check Released Plugins Section
    This Version Requires RideRunner 11/1/09
    RRVoiceControl Version 1.1.0.83 BETA Copyright 2009 The Garage
    RRVCConfig Version 1.0.0.44 BETA Copyright 2009 The Garage
    Developed for Driving Safety while using RideRunner Frontend.
    RRVoiceControl was developed using DFX 4.0 skin
    It should work with any skin.
    RRVoiceControl is a Voice Control Application based on SAPI 5.1 VR
    You must have SAPI 5.1 VR installed and setup for it to work.
    Unknown if newer versions of SAPI are compatible.
    Developed and Tested on Windows 2000
    Unknown if newer versions of Windows are compatible.
    Developed using Visual Basic 6.
    If you have RideRunner installed you should have all VB6 runtime files needed.
    RRVoiceControl was developed for my personal use.
    I am offering it free of charge for personal use.
    No Refunds. Use at your own risk.
    ## SETUP ##
    Turn off RideRunners built in VR in rr.ini if you have it on.
    Make sure that SAPI and your Microphone is set up correctly.
    To hear system beeps, Make sure your "PC Speaker" volume is set correctly.
    Unzip and Drop the files into any folder of your choice, preferably "C:\Program Files\RideRunner\RRVoiceControl"
    Open RideRunner to expose RR's API then
    Open RRVoiceControl to set ini vars from RR and
    RRVoiceControl will minimize to system tray, right click on it and pop it up, then
    Open RRVConfig and Click the "Create" Button and let it find your MP3 and WMA files.
    Note: Currently only finds MP3 and WMA Files.
    You will note that you have full ini editing capabilities in RRVConfig.
    Debug is on by default in both apps, Leave it on for now.
    You can close RRVConfig now if you wish.
    ## Testing ##
    Take a look at and scroll through the default commands listed in the Commands Listbox in RRVoiceControl.
    I have it currently setup with a few default commands as you can see in the Commands Listbox.
    Now click on the word "VR OFF" on the RRVoiceControl form or
    Use the skin commands as noted below or
    Use serialswitch and a momentary button as noted below
    To enable VR.
    You will hear a beep and "VR OFF" will change to "VR ON".
    Say "Audio" and you will hear a different beep and see the application and RR recognize your command.
    There is a lower frequency beep for an unrecognized command. If so repeat your command.
    If everything is correct you will see the RideRunner command in bold at the bottom of RRVoiceControl and RR will change to Audio skin.
    If not. Go back and Setup or Train SAPI or Setup your microphone correctly.
    If you don't hear the system beeps, Make sure your "PC Speaker" volume is set correctly.
    I will not provide support for your SAPI VR or Microphone issues.
    ## RideRunner Exectbl.ini and Skin Commands ##
    This is what I have at the top of my DFX4 Exectbl.ini. Look towards the end of the "ExtraPrograms" line.
    "ExtraPrograms","2DLogo||UserSwitch||CDLaunch||Cou nter||3DLogo||SetTempBackground||PresetLoader||IGS ettingLoader||SETVAR;RRLoaded;Loaded||ReLock||Load List||RELAYS||RRVC"
    "RELAYS","RUN;$RRPATH$SerialSwitch\SerialSwitch.ex e"
    "RRVC","RUN;$RRPATH$RRVoiceControl\RRVoiceControl. exe"
    This is what I have at the bottom of my DFX4 Exectbl.ini
    You must have these commands for RRVoiceControl to work properly
    / RR Voice Control
    "ONRRVC_ON","SETIND;!RRVC_Ind;ON"
    "ONRRVC_OFF","SETIND;!RRVC_Ind;OFF"
    "RRVCON","SENDMSG;RRVoiceControl;RRVC_ON"
    "RRVCOFF","SENDMSG;RRVoiceControl;RRVC_OFF"
    "VOL+","VOL+||SENDMSG;RRVoiceControl;RRVC_VOLU ME"
    "VOL-","VOL-||SENDMSG;RRVoiceControl;RRVC_VOLUME"
    "QUIT","CLOSEWINDOW;RRVoiceControl||ENDVC"
    "ENDVC","QUIT"
    ## Explanation of Commands ##
    Executed "ON VR ON" or "ON VR OFF" from RRVoiceControl.
    ONRRVC_ON
    ONRRVC_OFF
    Example Indicator Code in Exectbl.ini:
    Turns VR ON or OFF, must be sent with sendmessage as shown below.
    RRVC_ON
    RRVC_OFF
    Example Button or Label Code in Exectbl.ini:
    VR shuts off after each command recognized.
    You must have this in Exectbl.ini to have Volume drop when issuing commands.
    ## Skin Commands ##
    Example Menu Skin Hidden Label Command to Enable/Disable VR.
    This puts a large hidden executable label in the center of the Menu Skin to switch VR on.
    L,301,235,204,124,,,,,,"EXEC;RRVCON||=",
    This puts a smaller hidden executable label in the center of the Menu Skin to switch VR off.
    L1,443,371,91,85,,,,,,"EXEC;RRVCOFF||=",
    Example Skin Indicator Code
    I have a couple of pngs embedded in my menu_on and menu_off pngs
    I,252,150,21,20,"!RRVC_Ind"
    I use SerialSwitch to enable VR with an External Button
    Here is the Exectbl.ini code I use for SerialSwitch.
    You can see above I load SerialSwitch with Exectbl.ini also.
    /-------------SerialSwitch-----------------
    "DTRON","SENDMSG;SerialSwitch;DTR_ON"
    "DTROFF","SENDMSG;SerialSwitch;DTR_OFF"
    "RTSON","SENDMSG;SerialSwitch;RTS_ON"
    "RTSOFF","SENDMSG;SerialSwitch;RTS_OFF"
    /"ONDTR_ON",""
    /"ONDTR_OFF",""
    /"ONRTS_ON",""
    /"ONRTS_OFF",""
    /"ONCD_ON",""
    /"ONCD_OFF",""
    /"ONCTS_ON",""
    /"ONCTS_OFF",""
    Turns on VR
    "ONDSR_ON","SENDMSG;RRVoiceControl;RRVC_ON"
    Turns off VR
    /"ONDSR_OFF","SENDMSG;RRVoiceControl;RRVC_OFF"
    "QUIT","CLOSEWINDOW;SerialSwitch||ENDIT"
    "ENDIT","QUIT"
    ## Momentary Switch Setup ##
    Turn RTS on, with skin command or manually in SerialSwith, to provide PC power to Pin 7
    DSR input is Pin 6
    I am using pins 6 and 7 to connect a momentary pushbutton switch
    Push switch and VR is on.
    ## Editing Ini Files ##
    RRVoiceControl is fully configurable.
    Any Voice Command in RRVoiceControl.ini can be associated with any or multiple RR Commands.
    This should be self explanatory by studying the ini files.
    Note: No command will show up twice in the Command list
    ## Music ##
    RRVoiceControl utilizes a new command in RideRunner to eliminate the need for hidden playlists in every skin.
    This new command is PLAYITEM;xxx Where xxx is playlist position of current playlist.
    This is one area I have put a lot of effort into getting right. I have 1150 songs. Some of you have over 10,000 songs.
    When you clicked on the "Create" button in RRVConfig you will have found out if this works.
    Thats why there is a stop button. Might have issues there. The command list should handle the last folder names.
    The songs for each folder are only listed when a folder command is given. Example: Load Eagles, lists the songs for that folder.
    This brings us to your music structure. I use the last folder name as you will see. Future effort will be to expand on this.
    This also brings us to song names. There are some album/song names that just don't lend themselves to voice recognition.
    Take for example Korn, 4U or Korn, K@#0%! How in the hell is VR gonna recognize those commands? How are you gonna say them?
    In VR all numbers must be spelled out for the command match. Ha! spell this, K@#0%!. You can't.
    So to get VR to recognize these, they must be edited in your Music.ini or Songs.ini. Change them to something VR can recognize.
    If you don't, you can't VR these songs. Just change the K@#0%! to something you can say.
    Use RRVConfig to do this. There is a Find Function, a Set Value Function, and a Delete Key Function.
    If you change the structure of your Music Paths, you must Delete and Create your ini files in RRVConfig.
    RRVConfig will make backups of your RRVoiceControl.ini, Music.ini, and Songs.ini files.
    Remember you might have changed K@#0%! to something VR can understand
    Now Start RideRunner, Start RRSkinTool, and start setting up your VR Menu Commands for your favorite skin.
    Please post the bugs...
    I'm sure I missed something in the app and or in this readme. Remember, This is BETA. Questions? Ask...
    ...JJG
    ...JJG
      Nice!
      Ride Runner RR's Myspace
        Sub'd. Looking fwd to this.
          Looks fantastic! Gonna give it a try now.
          My Fiero Build Thread
            Ok, sorry first bug report. I can not for the life of me get it to scan my music collection. I hit Setup, DefaultMediaPath, and put the value of H:\MP3 in the key, and then "Set Key".
            When it searches, it finds 328 files and stops. Looking at the songs.ini is even more confusing. It is getting stuff from all sorts of places. The DFX4.0/Scripts/CNN audio files, files from in Yahoo Messengers path, audio snippits from MSN Messenger path as well as scattered area's all over my drive C:
            I have deleted all files, and re-unzipped the app into:
            C:\Program Files\Road Runner\Plugins\RRVoice Control\
            I then run the exe again, and setup, defaultpath, set key... I have done this 5 times now, and it is still finding stuff from all over the place....
            Here is a section of the songs.ini. The new mail alert is from my Email Prog, the CNN stuff is from the DFX directory... ect ect...,
            [Program FilesMSN Messenger]
            Play newalert=SETLIST;1||PLEXEC
            Play newemail=SETLIST;2||PLEXEC
            Play nudge=SETLIST;3||PLEXEC
            Play online=SETLIST;4||PLEXEC
            Play outgoing=SETLIST;5||PLEXEC
            Play phone=SETLIST;6||PLEXEC
            Play type=SETLIST;7||PLEXEC
            Play vimdone=SETLIST;8||PLEXEC
            [Program FilesRoad RunnerskinsDFX Release BuildScriptsCNN-News]
            Play CNN-News-05-25-09-7PM=SETLIST;1||PLEXEC
            Play CNN-News-10-12-08-11PM=SETLIST;2||PLEXEC
            Play CNN-News-10-12-08-7PM=SETLIST;3||PLEXEC
            Play CNN-News-10-12-08-8PM=SETLIST;4||PLEXEC
            Play CNN-News-10-13-08-12AM=SETLIST;5||PLEXEC
            [Program FilesRoad RunnerskinsDigitalFX 3.0ScriptsCNN-News]
            Play CNN-News-06-29-09-6AM=SETLIST;1||PLEXEC
            [Program FilesRoad RunnerskinsDigitalFX 5.0ScriptsCNN-News]
            [Program FilesRoad RunnerskinsInnovatekScriptsCNN-News]
            [Program FilesSWiSHmaxsamplesTutorials]
            Play 88A=SETLIST;1||PLEXEC
            Play movie=SETLIST;2||PLEXEC
            [Program FilesWinamp]
            Play demo=SETLIST;1||PLEXEC
            [Program FilesYahoo!MessengerMediamisc]
            Play applause=SETLIST;1||PLEXEC
            Play grouplaff=SETLIST;2||PLEXEC
            Play moan=SETLIST;3||PLEXEC
            Play ooh=SETLIST;4||PLEXEC
            Play scream=SETLIST;5||PLEXEC
            [WINDOWSsystem32oobeimages]
            Play title=SETLIST;1||PLEXEC
            Here is a snippit from the Music.ini. It contains all sorts of programs, scripts and such that are in a folder on my desktop, none of which are .mp3 files:
            [Artists]
            Load Documents and SettingsJohnDesktopDigitalFX=Documents and SettingsJohnDesktopDigitalFX
            Load Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffLyric Parser Scripts=Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffLyric Parser Scripts
            Load Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffTemp ReadArtist=Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffTemp ReadArtist
            Load Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffTempMP3=Documents and SettingsJohnDesktopDigitalFXAll Lyrics StuffTempMP3
            Load Documents and SettingsJohnDesktopDigitalFXDigitalFX InnovatekScriptsCNN-News=Documents and SettingsJohnDesktopDigitalFXDigitalFX InnovatekScriptsCNN-News
            Load Documents and SettingsJohnDesktopDigitalFXPlay Intro When RR Starts=Documents and SettingsJohnDesktopDigitalFXPlay Intro When RR Starts
            Lastly, here is the paths section from the RRVoiceControl.ini, and it is saving the path correct to my music root folder correctly: (I tried the music path both with and without the trailing slash (\)
            [Paths]
            DefaultLoadPath=C:\Program Files\Road Runner\Plugins\RRVoice Control
            DefaultMediaPath=H:\MP3\
            EDIT:
            By the way, all of the other commands, aside from selecting music, are working perfectly! I am able to jump to the CD changer, weather, menu's ect ect... Very nice! Very nice job for a Beta!
              Sorry another small problem haha! A bug, and a solution....
              For others that are testing this, when you click the VR Off in the menu to speak to the system, move your mouse off of that area after you click it. If you do not move the mouse, it will continue to listen causing it to appear hung up.
                Works very nice! Also I had similar issues about music function, beside that fantastic, thanks!
                  subscribe
                  Riderunner / Genesis
                  Wifiman_NET:Version 1.0.0
                    I didnt have any issues creating the .ini files. Having to supply the default music path seems redundant though. Cant it just be read from RR? Does this plugin actually communicate with RR aside from the send messages?
                    Live mp3Car Facebook Chat
                      I use GPS speed to control my volume which obviously creates a variable situation. I use the volume controls on DFX 4 to choose between Volume- for windows down and Volume+ for windows closed. These choose 2 different GPS speed volume settings.
                      The attachement shows my code for both.
                      How do I proceed. I noticed that part of the code gets cut off in the set up.
                      And I am having the same problem as others with my music path. It seems like it does not recognize secondary hard drives ( D:\ ) and only searches the RR install drive ( C:\ ) for music.
                      Thanks.
                      CAR: 2007 G35 Sport Coupe 5AT
                      HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
                        I just tried this as a test, and the above is correct. I placed a single artist folder on my C:\ Drive and it created the songs.ini correctly. So the plugin seems to only accept music located on the system drive.
                        I can say "Load Abba" and the playlist screen loads, but then I can not play any of the songs.
                        I tried:
                        Play Abba One of us
                        Play one of us
                        load abba one of us
                        load one of us
                        and about 10 other spoken variations.
                          Okay so I figured this out for myself. In the RRVoiceControl.ini I changed the currentvolume to CurrentVolume=SETVAR in the paths section and I now can say Windows Open and it will set up my GPS volume settings for that, also works for Windows Closed.
                          My next step is to get the pc to open the windows and sunroof for me.
                            Okay I figured this out too. I deleted the music and songs .ini files and replace the VoiceControl.exe from the original zip. Lo and behold it found all the songs on the D drive.
                              My music files are on my D:\... I didnt have a problem.. so who knows.
