AW_Genie and RRTubex both trying to register the same File
  • AW_Genie and RRTubex both trying to register the same File
    As the subject states, we have a plugin issue. Both AW_Genie and RRTubeX are setup to register CxImageATL.dll in their respective directories. Will they both work if only one is registered? Will Windows barf if both are registered? Is there a way to check if its already registered? How best can this be resolved and keep my Windows Registry from exploding!
    My guess would be that there should be no problem if only one is registered. About having both registered, again shouldn't cause any problems except that you'll have an unused regd' entry in your registry. For the most part when you reg the same dll/ocx in different locations and a program needs to create a COM to it, it will use use last registered file from where it was registered.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Possible issue
      1. If the versions are different and one of the plugins uses features which are in one but not the other and that one is not registered, plugin may choke.
        Originally posted by Enforcer View Post
        Possible issue
        Luckily, same version, same size, same date.
