C++ Snippet Needed
  • C++ Snippet Needed
    I am trying to send TRACKNAME to an external program that is in C++, but I have no idea how to initialize or retrieve the data from the RideRunner SDK. The FAQ section has the following written in VB6:
    Code:
    Set RRSDK = CreateObject("RoadRunner.SDK")
    ' To Get information from Road Runner
    CurrentSong = RRSDK.GetInfo("TRACKNAME")
    I want to do the same thing in C++. Anyone out there know what the C++ code should be?
    Code:
    Take a look here:
    http://www.codeproject.com/KB/COM/consoleactivex.aspx
    openMobile - An open source C# Front End (why choose openMobile?)
    - Always Recruiting Developers -
    Like what you see? Donations are always welcome
      The above should work fine, and there are alternatives to receiving data from RR such as using the SendMessage API (WM_COPYDATA) also demostrated in the SDK examples.
      Ride Runner RR's Myspace
        [SPOONFEED MODE ON]
        Would someone please translate the above and list the necesary #include, #define, and variable definitions needed to acquire and pass the data to another output in C++.
        [SPOONFEED MODE OFF]
          [DEVIL ADVOCATE MODE]
          Gizmo, do you know the basics of C++ programming?
          If so you should be able to work it from the link
          If not, then I'm not sure you should be trying to do it, till you have some more C++ programming under you belt.
          [/DEVIL ADVOCATE]
            [/DEVIL ADVOCATE]
            Its been 25 years since I did any serious programming. I'm too old to want to learn another programming language. So how much do you want.... to do it for me. At this point in my life, I have more money than time. PM incoming.
