Plugin Error loading - Automation error
  • Plugin Error loading - Automation error
    I has developed a plugin on my desktop and it works well with RR. But it get error when I deploy it on car PC. Anything I missed? ("regasm /codebase /tlb RRefun.dll" run sucessfully on car pc)
    Plugin Manager: Error loading (menu.skin): RRefun (Automation error, check spelling of plugin, or its is COM registration missing.)
    I'd have to say it may be a .NET version/component issue then -- as it seems clear you're using .NET
    You may want to try making a simple test app that creates/calls a few functions of the RRefun.RRExtension class and see if it works in the carpc as well (probably wont).
    Ride Runner RR's Myspace
      Tested a simple plugin, it runs well. I guess the problem was caused by the referenced DLLs by plugin RRefun. Will check the referenced dlls one by one
