GPS-Based internet data
  • GPS-Based internet data
    Before the changes in RideRunner, I had weather and gas screens that would automatically load data based on GPS location when the screens were initially opened.
    How do I restore that functionality with the latest version of RideRunner? What should the RRCode look like or is it even possible anymore? If so, how can I refine it so it automatically loads based on GPS location the first time I run it , yet just show the exising data on subsequent returns to this screen?
    Can the dev team add a command to the weather plugin called GPSWEATHER? The docs don't show a command nor explain if an existing command performs a GPS-based data download/display.
    I know RRGas has a command, rrgas_gps, and I've figured out how to achieve the above, but a response from Enforcer with his suggestion for the RRCode to use would be appreciated.
    Looking at the new code/plugin it should be exactly the same as before, meaning, just have zips.dat available (so RR knows your current Zip code from the GPS data) and set the localdatacaptureinterval setting accordingly, the weather plugin will read that and auto-update in that interval whenever there's a GPS lock.
    Ride Runner RR's Myspace
      you might want to check the RR source guino i believe someone has broken the gps location stuff. Hasnt worked in a few months for me. I just figured it was scrapped so that someone could do it via plugin
      Live mp3Car Facebook Chat
        I thought I remembered this being scrapped, by whom I cant remember. But it had something to do with the zip.dat file and ziplocator.? file something or other. It was adding a lot of confusion. Anyway, just a memmory I think I had.
        maybe Im wrong, who knows...
        This was an awesome feature that has been lost for sometime now though.
        New Age Garmin - Skin for RR
          Blue separated the weather plugin, but zips.dat support is still in the core, and the weather plugin seems to have all the code ready for it.. I'll have to try it out to see then.
            How about the Exectlb code that used to work, might help in narrowing down either the issue or what you may need to modify to get it working again.
            Next in line: RRMedia v2.0
            DFX 5.1.1 Skin
            Appstore Link
            My RideRunner Plugins
            RRMedia
            RRExtended
            DFXVoice
              If J remember correctly, I believe the RELOADWEATHER command was run after the screen loaded and thats it. Now the reload doesn't do it anymore.
                When I was working in the weather PI last night... I did look and yes the "RELOADWEATHER" cmd looks to see if you have an valid gps AND your locate city lbl contains something and if both true then uses that info otherwise defaults to cityweather setting. If I remember correctly, I didn't change any of that part was just a cut N paste into the PI.
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
                  Sorry missed this.
                  What exactly do you want to do?
                    Its a weather question not a gas one.... look n read first...
                    DFX 5.1.1 Skin
                    Appstore Link
                    RRMedia
                    RRExtended
                    DFXVoice
                      He was using it as an example...duh. Asking if there was a similar cmd for weather PI now
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        The OP was for both.
                        I will change my weather code back to RELOADWEATHER and verify.
                        I am curious what the developer of RRGAS would suggest as code to put in the exectbl.ini to get RRGAS to load the gas.skin and pull the internet data immediately for the current GPS location.
                        Thanks Blue for looking into the weather PI and Enforcer I await your reply.
                          Try this
                          "GAS","BYVAR;GASFIRST;RRGAS||RRGAS_GPS||SETVAR;GAS FIRST;1<<RRGAS"
                          note: no space in GASFIRST
                          and add to ONRESUME
                          "SETVAR;GASFIRST;0"
                          and to ONSKINSTART (if required)
                          "SETVAR;GASFIRST;0"
                          and Blue
                            Originally posted by Enforcer View Post
                            Try this
                            and add to ONRESUME
                            "SETVAR;GASFIRST;0"
                            "SETVAR;GASFIRST;0"
                            Well I was close. Didn't think to use a variable that way. Thanx
                            and Blue
