Visualisation for foobar
  • Visualisation for foobar
    I use f2k player plugin in RR
    I have idea to change style vis of foobar by use " foo_vis_shpeck.dll " this is vis plugin winamp for foobar and use " foo_runcmd.dll " to run command
    Step:
    1. install winamp 5.xx. I test with 5.22,5.24
    2. install foobar components
    3. add shpeck in ui foobar without shpeck titlebar
    4. in foobar shoose autostart plugin shpeck(AVS) and don't select stop when hidden
    5. open rrconfig musicsetup page2 changename vis from foobarvis to AVS set transparents vis if you want
    6.edit command on your skin to run AVS
    I use this command to run avs in RR
    "LOAD;audio_visuals.skin||VISU||run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'""
    Click image for larger version
    I definitely have to give you credit for researching this stuff on your own.
    Ride Runner RR's Myspace
      Thank you
      Now In this case .. I can not complete to close avs...when I close vis page the avs window running on background ( "VISU||EXIT" )
      when I stop by foobar cmd and run vis page again avs not appear ?? I dont understand.
      "VISU||EXIT||run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="View/Visualisations/Shpeck - Stop"""
        When using the vis with the foo_runcmd.dll (your way described here), I would suggest you to not use the VISU command and instead did this:
        To Start Visu:
        Code:
        "LOAD;audio_visuals.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$"
        To Stop Visu:
        Code:
        "EXIT||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Stop""
          I test your newest option plugin vis for foobar
          its work very well..
            im trying to do the same things and i can't get it to work. like "anuchit" said on #5
            "5. open rrconfig musicsetup page2 changename vis from foobarvis to AVS set transparents vis if you want"
            after i do that and run rr, it changes back to "foobarvis" from AVS
            also, inside the skin when i assign a string to a button as described above by using "foo_runcmd.dll" it runs visualization but the foobar's default "Spectrum"
            and when i execute command to exit vis, i get an error message:
            "unknown commandline parameter: /runcmd=View/Visualisations/Shpeck - Stop"
            I also tried to use command for the button as "anuchit" initially listed and it returned with an error:
            "unknown commandline parameter: /runcmd=View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'"
            Any suggestions?
            Specs:
            win XP-pro
            RR 03/02/2010
            winamp 5.572
            foobar 0.9.6.9
            foo comserver2 0.7
            foo vis shpeck 0.3.7
              Oh no qazaq9
              That i create myself not good
              Please go to foobar player plugin this option create new vis option by Guino..Its work ..
                I try to do the same thing, but i have not the same screen:
                I have that and i don't know why:
                and i should like that :
                If i change the visuname from FoobarVis to AVS, that don't run for me!
                this command run well the visu but not that i want:
                Code:
                B,2,427,073,27,"LOAD;audio_playerCWD.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$",
                this command run well the exit command but don't exit from the foobar visu:
                Code:
                B,1,460,073,27,"EXIT||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Stop"",
                Is my shpeck settings good ?
                  Please read step by step by Guino on the first page
                  http://www.mp3car.com/vbulletin/rr-r...er-plugin.html
                  and see my guide picture
                  This is spectrum analyzer that u like...
                    All run very well for me.
                    Where do you put the avs files ?
                    That i don't know is that i must to push on the shift+alt+v to run the avs .
                    Also i have make an autoit script that do it for me.
                    But i don't know how to do shift+alt+v in autoit.
                    Also i modified shift+alt+v by Alt+F1 , i upload my little job (you must to change the key short in foobar).
                    and my command is:
                    Code:
                    B,2,427,073,27,"LOAD;audio_playerCWD.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$||run;$skinpath$Scripts\RunAvsFoobar.exe",
                      foo_vis_shpeck.dll is component for foolbar
                      Its connect from winamp to foobar
                      U must install winamp
                      AVS file in path c:/program files /winamp/plugin/avs
                      to run avs use basic command on RR "VISU"
                      no need autoit....
                        Is there a way to only use the spectrum vis without deleting the rest of them. It seems as if it's statically set to ramdom??
                        Check out my 2006 Yukon XL Project
                        http://www.mp3car.com/vbulletin/show...ject-pics.html
                          I found just the 2.81b not the 2.83.
                          Who as a good link please ?
                            Its builtin winamp lasted version
