RideRunner & Delphi Plugin
  • RideRunner & Delphi Plugin
    Hello from Austria,
    i am the new guy and fan of Riderunner
    I use this great software for about 2 Months.
    Now is time to write the first plugin.
    I am working on a temperature plugin using a 1-wire USB Adapter and DS1920 sensors.
    This part is okay, my problem ist to send a message to RideRunner.
    I found this example, but i can't get it work.
    Has anybody a working example for Borland Delphiform me !?
    Thank you in advance
    Tesla76
    Code:
    unit Unit2;
    interface
    uses
      Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
      Dialogs, StdCtrls;
    const
      WM_COPYDATA = 74;
    type
      TMyCopyDataStruct = packed record
        dwData: DWORD;
        cbData: DWORD;
        lpData: Pointer;
      end;
    type
      TForm1 = class(TForm)
        Button1: TButton;
        Edit1: TEdit;
        procedure Button1Click(Sender: TObject);
      private
        procedure WMCopyData(var Msg : TWMCopyData) ; message WM_COPYDATA;
      public
        procedure SendCopyData(hTargetWnd: HWND; ACopyDataStruct:TCopyDataStruct);
      end;
    var
      Form1: TForm1;
      MyCopyDataStruct: TCopyDataStruct;
    implementation
    {$R *.dfm}
    { Use: "SENDMSG;<FORMTITLE>;<TEXT>" from RR to receive data here }
    procedure TForm1.WMCopyData(var Msg: TWMCopyData) ;
    var
      s : string;
    begin
      s := PChar(Msg.CopyDataStruct.lpData) ;
      SetLength(s, Msg.CopyDataStruct.cbData) ;
      // Displays Received Data
      showmessage(s);
      //Send something back
      msg.Result := 1;
    end;
    procedure TForm1.Button1Click(Sender: TObject);
    var
      txt: string;
    begin
      with MyCopyDataStruct do begin
        dwData := 1; // may use a value do identify content of message
        cbData := StrLen(PChar(Edit1.Text));// + 1;  //Need to transfer terminating #0 as well
        lpData := PChar(Edit1.Text)
      end;
      sendcopydata(findwindow(nil, 'RideRunner'), MyCopyDataStruct);
      sendcopydata(findwindow(nil, 'RoadRunner'), MyCopyDataStruct);
    end;
    procedure TForm1.SendCopyData(hTargetWnd: HWND; ACopyDataStruct:TCopyDataStruct);
    begin
      if hTargetWnd <> 0 then
        SendMessage(hTargetWnd, WM_COPYDATA, Longint(Handle), Longint(@ACopyDataStruct))
      else
        ShowMessage('No Recipient found!');
    end;
    end.
    You may want to try something like this instead..
    Code:
    procedure TForm1.InsertBtnClick(Sender: TObject);
    var
      S: string;
      RRSDK: Variant;
    begin
      try
        RRSDK := CreateOleObject('RideRunner.SDK');
      except
        ShowMessage('Could not start RR.');
        Exit;
      end;
      RRSDK.Execute('PLAY');
      S := RRSDK.GetInfo('TRACKNAME');
    end;
    I highly recommend you reading the method "3" of this link:
    http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
    The method you were trying to use (while it should still work) is more complex and offers no benefit over the COM method above described.
    Ride Runner RR's Myspace
      @guino
      Thank you very much !!
      Your solution is very easy (perhaps to easy) and working like a charme !!
      I read this 20 times bevore, but i don't know that creating an COM Objekt in Delphi is so easy !!
      Now my prog is updating the temperature with the SETVAR command.
      Tesla
        That would be a good idea to have a Delphi plugin example ready to use and modify
