Help with displaying weather icon on main menu
  • Help with displaying weather icon on main menu
    Hey, just started skinning and I'm wondering how to load the weather info (preferably just day 1) when loading / starting up RR. I can get the wicon to show if I enter/exit weather.skin, so I know it works. Just not sure on how the skin loads the weather info.
    bump
      at a guess i would add RELOADWEATHER to your onskinstart line in your exectbl.ini
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        no go :\
          This should be put in your skin exectbl.ini
          Originally posted by JimL View Post
          no go :\
          Should have worked for you. Works great for me.
          Here is where I put RELOADWEATHER
          Code:
          DigitalFX Skin Code & Commands
          / -------------------- Things to run, and get settings on Digital FX's Start ------------
          "OnSkinStart","WinPresetLoad||SetApps||SetCommandLabels01||SetAppLabels||SetIcons||ExtraPrograms"
          "ExtraPrograms","SETVAR;RRLoaded;Loaded||QWERTY||[HL]RELOADWEATHER[/HL]"
          "CDLaunch","RUNQ;$SkinPath$Scripts\AutoLaunch.exe"
          CAR: 2007 G35 Sport Coupe 5AT
          HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
            stupid thing, I actually managed to mis-type it.
            Works like a charm Thanks
              Just a note:
              "RELOADWEATHER" command will load the the weather for your current location if you have a GPS signal.
              If you want to load the weather for the city you have chosen for CITYWEATHER then you need to use "RELOADHOMEWEATHER".
              My Fiero Build Thread
