RRShoutcast not working
  • RRShoutcast not working
    Hey guys!
    Not sure if anyone else has run into this but just the other day I attempted to run rrshoutcast and found that the lists come up blank (genres, ect.). Now, recently I've updated RR to the Jan 2012 release and I'm not sure if that had something to do with it as I've been unable to test prior versions (stupidly deleted the old installers). I've tried uninstalling and re-installing both RR (Jan 2012) and winamp (5.0623) without any luck. Currently running Windows 7.
    I'll check if it still works for me in the AM. I havent used it or worked on in in awhile though. I'll reply here and let you know whats going on.
    Live mp3Car Facebook Chat
      Thanks Sonic. I appreciate it.
      -Nick
        Confirmed Shoutcast removed there prior API for an all new one. I will look into converting to their new setup.
          Which API is that? I just checked my CF app and it's working fine (for now). It uses the backend, Version 2 registered API, but it wouldn't surprise me one little bit if that changed soon.
          VegasGuy
            VegasGuy
            It was there first one i believe. Just raw xml requests. I know they redid their api again in 2009 or 2010, but left the old calls in tact. But they no longer work with the revision they did in 12/11.
            For instance, this line no longer populates the primary genre list
            Code:
            http://api.shoutcast.com/genre/primary?k=so1KMHAXDrkXaMD8&f=xml
              anddd AOL is no longer accepting "partners" for the new API access. Project is going to have to be on hold until they open registration
                Thanks for at least confirming that it wasn't something wrong with my computer. Hopefully we can get a working solution in the near future.
                  hi, i have the same prob with shoutcast, just wondered if a fix has come up
                  thanks daveo
                    well this sucks
                      Check the plugin thread or autoappmart the fix has been available for several weeks. With more features to boot
                      Sent from my Transformer TF101 using Tapatalk
                        thanks. ive obviously been looking for answers in the wrong places
                          hi thanks for the info but i have downloaded the latest version 5.8 from autoappmart but still it does not find any stations,all so none of the buttons work at the bottom of the skin..
                          thanks daveo
                            hi all, OK i have un-installed and re-installed shoutcast, running 5.8 but still i don't get any stations. is there any thing that i am doing wrong. any suggestion what to check will be great.
                            thanks daveo
                            win amp 5.62
                            wifi man
                              same here :/ i just updated everything and it still wont show stations. are you using the internet radio plugin in dfx5 like i am? or shoutcast directly?
