Use Textbox as variable
  • Use Textbox as variable
    I look for a way for load a variable result into a TEXTBOX into a VB.NET plugin.
    How can i do that please ?
    Hox can i see TEXTBOX var into the skintool ?
    Thanks for all help !
    The only text box in RR is for the OSK as far as I know - for those you have to use OSKTOVAR, OSKTEXT and similar commands.
    If you want to display some other text box, then you have the option to make a label that looks like a text box and just use on screen buttons to type/change it OR you can simply make a screen in your application and embed it in RR as any external application (using load command). Then you'll have full control of what to do with your text box which you can then use to set variables in RR if desired.
    Ride Runner RR's Myspace
      from a plugin....
      you can access in processcmd, frm.OskText()
      will return string
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        Better example...Used in my RRExtended PI. Get or set the first textbox text in the current screen.
        Get Text:
        txt = frm.Txt(0).Text
        Set Text:
        frm.Txt(0).Text = txt
        ** Has to be called in the ProcessCommand sub
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          Get Text:
          Set Text:
          You can save the reference to the screen (frm) and use it from outside processcommand as well, it's just safer to use it in processcommand.
            Thanks to all for these answers !
