How to check the RR message (Command Not Executed: MYCOMMAND) into a VB6 plugin
  • How to check the RR message (Command Not Executed: MYCOMMAND) into a VB6 plugin
    Hello all,
    I try in a VB6 plugin to check if a RR command return or not an RR error into skintool as : (Command Not Executed: MYCOMMAND)
    I have tried these lines but without success !
    Code:
    Public Sub Test(text As String)
        On Error GoTo ErrorHandler
        RRSDK.Execute ("MYCOMMAND")
    ErrorHandler:
        RRSDK.ErrScrn "RR plugin Error !!!", "The 'MYCOMMAND' command isn't found into your ExecTBL.ini file !", "ex : ''MYCOMMAND'',''MENU;MYSCREEN.SKIN''", 15
    End Sub
    Thanks for your help
    No guy can help me ?
      How do you compare the command in exectbl.ini?
      Why do you need this?
      RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
      RR-Plugin: IBusCommunicatoRR new Updates
        My goal was to have RR EVENTS into VB6 as i can to have in VB.NET
          insert to RRExtension.cls
          Code:
          Public Function ProcessCommand(CMD As String, frm As Object) As Integer
              Select Case LCase(CMD)
                  Case "mycommand"
                      yourfunction()
                      ProcessCommand = 2
              End Select
          End Function
          Don't understand why do you want compare the exectbl.ini with working commands in riderunner.
          edit:
          did a test. becauseof the LCase use small letters to catch the command.
            Code:
                    Case "mycommand"
                        yourfunction()
                        ProcessCommand = 2
                End Select
            End Function
            edit:
            I know already know that ! I work with each day ! It's the base of the RR plugin !
            The RaiseEvent function don't exist in VB6 and it's a problem
              Sorry, don't wanted to disabuse you.
              Why is there a probleme?
                Create your specific RR event into your exectbl.ini file as:
                "ONMYSPECIALEVENTTHATILOVE","MYSPECIALCOMMAND"
                The goal would be to send a RR command from the plugin that RR can see an run the MYSPECIALCOMMAND defined into your exctbl.ini file
                  don't know why you have problems. in my case, it is working.
                    Code:
                            Case "mycommand"
                                yourfunction()
                                ProcessCommand = 2
                        End Select
                    End Function
                    With this code example, if you add nothing into your exectbl.ini, the skintool return that the command mycommand isn't found
                      not correct.
                      the cmd mycommand runs the function in the plugin. has nothing to do with exectbl.
                      if you send from plugin and set in exectbl, you just see the following command in skintool. the command from plugin is hidden, but working.
                      if you don't set in exectbl, you get the error.
                        not correct.
                        Exact , but with VB.NET , if you don't set the RR event into the exctbl.ini that don't give an error into the skintool !!!
                          oh,now i think to understand.
                          Does it mean you want get this error with vb .net?
                          or
                          You want cancel the error with vb6? But why?
                            I want cancel the error with vb6 ! My goal was to create RR EVENT as that already exist into RR .BY example ONEXIT etc...
                              ok. i have an idea. will try it today evening.
