RR DAB Monkey Radio RR plugin
  • RR DAB Monkey Radio RR plugin
    Need some beta tester that use the DAB+ radio !!!
    This actual version don't run with winamp !!!!
    Need some feed back , thanks !!!
    Video of v0.5 By mspw : http://youtu.be/zcZS-pN3V3Y
    Main screen:
    Click image for larger version
    First settings screen:
    Thanks to mspw and mos33y for the help in the debug !
    Second settings screen:
    started testing thi PI, but we do need a few more testers with various pc configs. I am currently testing on win8 32 bit.
      PM sent
        I got the monkeyboard, willing to test :-D
          new version v0.6
            PM sent
              Hi mate, your inbox is full
              I've compiled 2 videos that cover the issues we've discussed re: version 0.6/0.7. Problems with radio staying on after exiting Roadrider has been fixed in 0.7.
              Here are the links to both new videos - http://youtu.be/LQjyuRyFAlE
              http://youtu.be/xELcCm13nIM - video 2
              BTW
              Could I suggest a different button layout for the next plug-in?
              On/Off (toggle rather than 2x separate buttone)
              DAB / FM
              scan left / scan right
              RESCAN / SEARCH - as discussed in video
              mute / reset
              Your plug-in and 6th Logics demo software are the same as far as reception percentage - shows 60% volume when probably should be 100%.
              BTW, I do yell a little in vid 2 - headphones are at high volume but my screen recorder doesn't pick up on that (although it probably sounds like the wife dropped a fork under the table)?
                On win. xp sp3 exit rr radio remains On
                In rrconfig need to select radio??
                Can use linein plugin???
                  test
                  skin for dfx5 and psd
                    Thanks for this share !
                    I have updated the installer with your DFX5 screens files !
                      With the skin dfx5 when I press on RR is not responding
                        For dfx on skin.ini
                        MenuExec_77=DABMONKEY
                        MainMenuExec_02=DABMONKEY
                        OK
                          Cool job :-)
                            I have the problem that RR it keeps crashing after hibernation when the plugin is loaded.
                            Have Windows 7 64bit and 0.8.1. What can I do so that I am running?
                            Have also tried to disable the plugin before hibernation but that did not work, because it's still loading.
                              same here. Win xp sp3.
                              Disabling plug in in RR does not work, it is active again after restart.
                              After avaking from hibernate RideRunner is not reacting.
                              Car: Volvo XC60
                              CarPc: intel D945CLF2, 7"-Touchscreen, RoadRunner, IGo8
                              HiFi: Diabolo D19/AndrianAudio A165g,2xPolk DB10, Signat RAMbo pimped, BRAX X2000
