Keyboard language indicator extension plugin
  • Keyboard language indicator extension plugin
    I want to make an indicator in RR which changes state when the keyboard language is changed. Is there anyway I can do this in RR (maybe an autoit script)??
    The road is long but we are getting there.
    You can do this as an extension plugin, but it will probably require some funky API calls..
    Ride Runner RR's Myspace
      So there is no other way of doing this apart from writting a plugin?
        Here we go
        Code:
        Option Explicit
        ' Declare API calls.
        Public Declare Function GetKeyboardLayout Lib "user32" _
        (ByVal dwLayout As Long) As Long
        ' CopyMemory takes the value in Source, and extracts the byte
        ' values from the number of bytes indicated by Length from
        ' Source.
        Public Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" _
              (Destination As Any, Source As Any, ByVal Length As Long)
        Function LowWord(ByVal lOriginalValue As Long) As Integer
        ' Returns the low word of a Long value. Therefore, if GetKeyboardLayout
        ' returns the value 67699721, this function extracts the decimal
        ' value of the of the first word in the lOriginalValue variable, and
        ' returns 1033 as the value of the first word of lOriginalValue.
        ' The Long data type is a 4-byte Integer that ranges in value from
        ' -2,147,483,648 to 2,147,483,647. A word is two bytes long.
           CopyMemory LowWord, lOriginalValue, 2
        End Function
        Sub test()
           Dim lKeyboardValue As Long
           Dim lResp As Long
           Dim lLangCode As Long
           Dim strLang As String
        ' Initialize lKeyboardValue to zero
           lKeyboardValue = 0
        ' Get the Keyboard Layout value.
           lResp = GetKeyboardLayout(lKeyboardValue)
        ' Extract the language code value.
           lLangCode = LowWord(lResp)
        ' Using the Select Case statement, match the code to one of the
        ' standard keyboard language types available to Microsoft Windows.
           Select Case lLangCode
              Case 1028
                 strLang = "Taiwan - Chinese, Traditional"
              Case 1029
                 strLang = "Czech - Czech"
              Case 1030
                 strLang = "Denmark - Danish"
              Case 1031
                 strLang = "Germany - German"
              Case 1032
                 strLang = "Greece - Greek"
              Case 1033
                 strLang = "US - English"
              Case 1034
                 strLang = "Spain - Spanish"
              Case 1035
                 strLang = "Finland - Finnish"
              Case 1036
                 strLang = "France - French"
              Case 1037
                 strLang = "Israel - Hebrew"
              Case 1038
                 strLang = "Hungary - Hungarian"
              Case 1040
                 strLang = "Italy - Italian"
              Case 1041
                 strLang = "Japan - Japanese"
              Case 1042
                 strLang = "Korea - Korean"
              Case 1043
                 strLang = "Benelux - Dutch"
              Case 1044
                 strLang = "Norway - Norwegian"
              Case 1045
                 strLang = "Poland - Polish"
              Case 1046
                 strLang = "Brazil - Portuguese"
              Case 1049
                 strLang = "Russia - Russian"
              Case 1051
                 strLang = "Slovakia - Slovakian"
              Case 1053
                 strLang = "Sweden - Swedish"
              Case 1054
                 strLang = "Thailand - Thai"
              Case 1055
                 strLang = "Turkey - Turkish"
              Case 1060
                 strLang = "Slovenia - Slovenian"
              Case 2052
                 strLang = "China - Chinese, Simplified"
              Case 2057
                 strLang = "UK - English"
              Case 2060
                 strLang = "Benelux - French"
              Case 2070
                 strLang = "Portugal - Portuguese"
              Case 3081
                 strLang = "Australia - English"
              Case 3084
                 strLang = "Canada - French"
              Case 4105
                 strLang = "Canada - English"
              Case 5129
                 strLang = "New Zealand - English"
              Case 13321
                 strLang = "Philippines - English"
              Case 14345
                 strLang = "Indonesia - English"
              Case 15369
                 strLang = "Hong Kong SAR - English"
              Case 16393
                 strLang = "India - English"
              Case 17417
                 strLang = "Malaysia - English"
              Case 18441
                 strLang = "Singapore - English"
              Case 58378
                 strLang = "LatAm - Spanish"
              Case 58380
                 strLang = "North Africa - French"
              Case Else
                 strLang = "Not listed"
           End Select
        ' Display a Message box with the language code and name.
           MsgBox "The Keyboard language is: " & lLangCode & ": " & strLang
        End Sub
          Thanks a million Evo but what version of autoit is this for. I keep on getting error when I try to compile
            This is VB6 code. What error are you getting?
              Oops!! I though it was autoit. Sorry my bad. I'll try it out with VB and let you know.
                Just call "test" method from your testing app to get keyboard
                  I can’t place the code in a VB6 project. Don’t laugh I’m not a programmer.
                  Could you please insert the above code in a VB project and post the project ready to compile?
                    Here we go. But, what are you going to do with that if you are not a programmer?
                      Thank you for all your time. I really appreciate it. I can code just enough to use what you have just provided. Thank you again
                        Go D6 Name thread and see last post of yesterday about VOSK : virtual Keyboard that use Windows'one with transparency so his configuration is the same your real keybord.
                          I tried out the code and it works great. Iím having a problem when I compile the code and make an .exe file. When I run the code from within VB everything goes OK but when I run the compiled file, the code does not do what it is supposed to do.
                          In brief, the program checks for the keyboard language. If it is Greek, it will copy a file from a source directory to a destination directory. If the keyboard language is not Greek it will erase the file in the destination directory. When the code is executed from within VB it does the above. When it is executed from the compiled file it does not. What am I doing wrong ?
                            Try c:\ instead of c:/ on the paths.. other than that, if it still doesn't work, remove exit_prog from form load and see if it works (should show a window then).
                              I tried both of your suggestion Guino both still nothing
                              When I run the .exe I can see the keyboard language change to English, even if it was set to Greek. Why is it doing that? The program runs fine in VB. It does not change the keyboard language and does what it is suppose to do.
