WinAmp Copy
  • WinAmp Copy
    Hi,
    i've made a simple tool to copy the file that WinAmp is playing. or the complete dir of the current file. it's also possible to copy directly to a ftp server. build in are warnings, only for copying dir's because of the potential large amout of data, and some space calculation in order to know if evertying is gonna fit.
    click here to download
    some screens:
    and the mini-mode
    there's also a RR plugin, this function is what started it all for me. both copy options (file or dir) are usable in RR only the FTP mode ISN'T.
    happy copying
    Cool, I guess this is useful (for instance) to those wishing to transfer songs from the car into their portable players .. I'm fortunate enough to have an MP3 player with as much capacity as my car has in music, but I'm sure others will appreciate it..
    Ride Runner RR's Myspace
      yep created it more or less with the though of one of my buddies sitting in the car and liking the song: plugin your portable-drive and click
        i wanted to download this plugin but i cant find it anywhere.
        can someone repost it ?
        best regards
        jelle
          ok downloads are HERE
          the one discussed in this topic is NOT a plugin but an additional program.
          that is WinAmpCopy.zip
          the plugin (not tested widely) is WinAmpCopyPlugin.zip
          sjors
            Hey Polomaniac,
            The download link does not contain the winampcopy files.
            Where can we download them from?
            Thanks!
              fixed
                It worked fine in my laptop but when I install in my carpc I get this error message:
                Class not registered
                You need the following file to be installed in your machine. MSSTDFMT.DLL
                  never had that error, but try to locat msstdfmt.dll on your laptop and copy it to the same dir on your cpc... reboot and try again..
                  sjors
                    Found it in windows/system32 folder. Copied to carpc(same folder) and register using regsvr32 and it works now.
                      yw
                        Is this plug-in still available?
                          yep, it can be downloaded here
                          made a while ago so maby it's not compatible anymore with the current version of RR
                          sjors
                            Cool... thanks.
                            Well there's only one way to find out
