Help to get the Radioshark plugin working
  • Help to get the Radioshark plugin working
    Help pls i'm trying to get the radio shark pluging into work, but all I get is the loading screen, I bet it something daft I not done but I followed the instructions. Radio shark works fine when using from windows so know the patch side must worked ok.
    in the menu.skin ini file I got as follows
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    menu_off.jpg,menu_off.jpg,menu_on.jpg,menu_down.jp g
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,11,73,339,106,"AUDIO","Audio player"
    B02,348,70,104,75,"CDRIP","Rip CD"
    B03,451,73,339,106,"VIDEO","Video player"
    B04,11,186,296,106,"RADIOSHARK","AM FM Radio"
    B05,494,181,296,116,"DVD",""
    B06,11,305,339,106,"XM",""
    B07,348,335,102,75,"WEB",""
    B08,451,303,339,106,"GPS","GPS"
    B09,10,416,150,110,"PHOCO",""
    B10,160,425,65,90,"MUTE","Mute"
    B11,226,427,63,88,"VOL-","Volume-"
    B12,515,426,63,89,"VOL+","Volume+"
    B13,581,425,61,90,"MIXER","Mixer settings"
    B14,643,415,145,110,"TV",""
    B15,10,530,156,70,"SKIN","Appearance"
    B16,166,530,156,70,"GAMMA","Gamma mode"
    B17,320,530,160,70,"LAUNCH",""
    B18,480,530,155,70,"MINIMIZE",""
    B19,633,530,156,70,"EXIT","Exit"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,290,466,223,35,290,466,223,35,H,01,"POINTER2.g if",013,"MASTER","Master"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,185,455,30,35,"MUTE:b"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L10,165,15,470,45,255,255,0,26,"Arial Narrow:B","TRACKNAME","SCROLL-CENTER"
    L00,415,440,50,30,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
    L01,30,10,135,30,255,255,255,18,"Arial Narrow:B","TIME","Time"
    L02,30,40,135,30,255,255,255,18,"Arial Narrow:B","DATE",""
    L03,660,10,50,30,255,255,255,18,"Arial Narrow:B","=Car:", ""
    L04,710,10,80,30,128,255,128,18,"Arial Narrow:B","TEMP1", ""
    L05,660,40,50,30,255,255,255,18,"Arial Narrow:B","=Out:", ""
    L06,710,40,80,30,128,255,128,18,"Arial Narrow:B","TEMP2", ""
    /, F, x, y, w, h, Movie name
    F01,333,162,135,160,"logo.swf"
    END
    in the radio shark ini I got the following information:
    # INI file for radioShark plugin
    # path of the radioShark executable
    radioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe
    # To allow radioSHARK plugin work as stand-alone app set standalone=true
    standalone=false
    # AM radio presets
    fm_preset_1=100.7;Y 100.7
    fm_preset_2=93.1;93.1 Rock Radio
    fm_preset_3=105.9;Classic Rock
    fm_preset_4=101.5
    fm_preset_5=103.1;The Buzz
    fm_preset_6=96.5;Power 96
    fm_preset_7=99.1;99 Jams
    fm_preset_8=94.9
    # AM radio presets
    am_preset_1=610;Public radio 610
    # radioShark Volume control steps
    volumestep=1
    # radioShark Volume control symbol
    volumesymbol=|
    # volumesymbol=*
    # volumesymbol=numeric
    # radioShark tune control step
    tunestep=1
    and in the Roadriunner ExecTLB ini file I got the following:
    /, This (OPTIONAL) file contains translation commands.
    /, RR will accept the commands defined on the LEFT
    /, and execute them as expressed on the RIGHT
    /, you can use this to create or redefine any command
    /, (or to add functionality to any syandard command).
    /, The Format of this file is (by choice):
    /, "<COMMAND>","<EXEC COMMAND>"
    /, "<COMMAND>","<EXEC COMMAND>",filename.skin
    /, Examples:
    /, "AUDIO","LOAD;audio_player.skin;Audio Player"
    /, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
    /, Extas:
    /, XM, FM and MM can be used instead of a skin file
    /, to be translated when XM, FM or MM is turned ON.
    /, PLAY, PAUSE and STOP can be used instead of skin
    /, file name so it executes commands based on MP3 or
    /, Video playback status.
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    /, Set Bellow the Path to the CDRip plugin (if used)
    "CDRIP","PLUGIN;RRCDRip;D:\VBStuff\Road Runner\CDRip\CDRip.exe"
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    "ONSUSPEND",""
    "ONRESUME",""
    "ONFILECLICK",""
    "ONDIRCLICK",""
    "ONPLCLICK",""
    "ONDLCLICK",""
    "ONPBCLICK",""
    "RADIOSHARK","PLUGIN;RRRadiosharkplugin;c:\RoadRun ner\radioSharkPlugin\radiosharkplugin.exe"
    Is it any errors you getting? Please explain the exact behavior. Where did you download the plugin. Rrdownloads.net does not have the latest version.
    Remove the space between n & n from "RoadRun ner"
    PS. Also you didn't have to start a new thread. Next time please post to the radioShark plugin thread.
    Just in case you don't know:
    in the next official release or RoadRunner radioSHARK will be supported natively(no plugin needed). please read this thread. You can already download it and test it.
      Wasn't getting any errors all that was happening was saying it was loading and then sticking. sorry didn't know there was a thread already open, Ok I went there and downloaded the download for RR as radioshark was already patched. Now the radio tunner opens but nothing happens I have changed the radiomode to 6 and below that put the line I need into the rr.ini file but don't get any sound. my radioshark works through windows fine on a usb lead
        1. Make sure you have a latest radioshark.exe installed on your computer.
        2. After installing the latest version make sure that you apply the patch.
        3. Make sure that the path to radioshark.exe in rr.ini is correct. Usually the path is:
        4. Since you are not using the plugin but native radioShark support in RR Please make sure that command to open radio in your menu skin is: “RADIO” not “RADIOSHARK”
        Are you testing it in your car or on your home computer?
          1. Latest radio shark is on system already downloaded from radio shark website, the verison installed is v 1.1.7
          2. The patch is working fine, because I tried it again and it said it's already been patched.
          3. in the menu.skin i got the following info since I downloaded the software from your link above.
          B04,11,186,296,106,"RADIO",""
          4. This is been tested on a home PC 1st before i change it to my car pc as it got a front ending working but i like the look of yours better so thinking of changing if this radio shark thing works.
          Ps. this is the information I have in the rr.ini file
          radiomode=6
          RadioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe
          radioline=0
